Turbo and Nitrous
I've been tossing this idea around for when I buy my next s2000 but I don't see much on here about the combo. Has anyone here ever tried it aiming for big numbers and quicker spool?
Both lower air intake temps, I pick meth over nitrous because you can also use meth/water as detonation safety.
If you are wanting a drag setup, and have a huge snail, and need a bump off the line sure, but with the new turbo's and twin scroll setups, I don't see the need much anymore.
Meth / water is just to make more power on pump gas, really won't help "spool" the turbo anymore per say, unless you start increasing timing, and even then isn't a big difference.
The plan for the car is to be a daily driver with the occasional trip to the track and races. So the nitrous won't be used all the time maybe a few times a month. But I'm aiming for 4 digit horsepower and close to 4 digit tq numbers with a 2.4 stroker on the juice. Sounds crazy for some but I think its doable.
What turbo are you planning on using? You may have to use a smaller size with the water/meth, I wouldn't run nitrous with a turbo for a daily...on the fast and furious it never works out right lol
