Turbo and Nitrous
Old Jul 8, 2013 | 07:14 AM
McMuffin's Avatar
Default Turbo and Nitrous
I've been tossing this idea around for when I buy my next s2000 but I don't see much on here about the combo. Has anyone here ever tried it aiming for big numbers and quicker spool?
Old Jul 8, 2013 | 07:24 AM
JUSTINTHECOASTIE's Avatar
Use meth instead
Old Jul 8, 2013 | 07:29 AM
McMuffin's Avatar
Any reason for meth over Nitrous? Ill have to check with the guy who will be tuning my car if he has experience with meth. I know he is a very good nitrous tuner.
Old Jul 8, 2013 | 07:41 AM
McMuffin's Avatar
Also the car will be on e85 24/7 since its readily available here in S. Fla.
Old Jul 8, 2013 | 10:09 AM
Both lower air intake temps, I pick meth over nitrous because you can also use meth/water as detonation safety.
Old Jul 8, 2013 | 10:16 AM
McMuffin's Avatar
Ah I see. Thats definitely a major plus.
Old Jul 8, 2013 | 10:48 AM
Check this older thread out https://www.s2ki.com/s2000/topic/966...o-and-nitrous/
Old Jul 8, 2013 | 01:08 PM
siadam's Avatar
If you are wanting a drag setup, and have a huge snail, and need a bump off the line sure, but with the new turbo's and twin scroll setups, I don't see the need much anymore.
Meth / water is just to make more power on pump gas, really won't help "spool" the turbo anymore per say, unless you start increasing timing, and even then isn't a big difference.
Old Jul 8, 2013 | 01:51 PM
McMuffin's Avatar
The plan for the car is to be a daily driver with the occasional trip to the track and races. So the nitrous won't be used all the time maybe a few times a month. But I'm aiming for 4 digit horsepower and close to 4 digit tq numbers with a 2.4 stroker on the juice. Sounds crazy for some but I think its doable.
Old Jul 8, 2013 | 03:01 PM
What turbo are you planning on using? You may have to use a smaller size with the water/meth, I wouldn't run nitrous with a turbo for a daily...on the fast and furious it never works out right lol
