Turbo oil feed and drain lines
I'm looking into replacing my turbo oil feed and drain lines.
I'm trying to figure out whether or not if the Jegs Push-loc hose would be suitable for the oil feed and drain.
I know that most of you are going to tell me to go with stainless steel braided lines.... but I only require info regarding to Push-Loc hose.
Yes it will work just fine. I can't remember off the top of my head but it has like a 250 psi rating. Seen many cars use it for their fuel lines. Just be sure it's either away from heat sources or has a sleeve over it.
