Turbo S2000 06+ DBW AEM V2 Idle Issues
Old Feb 17, 2015 | 10:41 AM
JayRSXS's Avatar
Default Turbo S2000 06+ DBW AEM V2 Idle Issues
So I went to get tuned last weekend and they pretty much had to pull a ton of ignition to get the car to idle reasonably low still in the 2500's and 3K+ without pulling any ignition. If you didn't know the 06+ keeps the stock ecu for the DBW. They are blaming my hondata 4 bar map sensor conflicting with the stock ecu and aem fighting for map sensor values. I can't be the only person running this setup and having this much problems. I don't want to use flash pro since it doesn't have a flex fuel option.
07 Honda S2000
FIC 1650's
Hondata 4 Bar Map Sensor
Flex Fuel
Precision 6765
Synapse Forward Facing Manifold
3" open downpipe exits at axles
-8 Feed -6 Return (43.5 / 3 bar)
Tial 44 Wastegate
Tial 50 BOV
Dual Intank FB 340s
AEM V2
AEM Wideband
I'm seriously about to part out this car and either get an 04-05. They are also asking me to purchase a stock map sensor which I already have to solve the stock ecu issues. Then purchase an AEM 5 bar map sensor to wire directly into the AEM unit. I threw a stock aem base map and its idling at like 3k still. Shed some light please.
My last option is flashpro but I seriously want flex fuel.
Old Feb 17, 2015 | 11:03 AM
Jin_SK's Avatar
07 Honda S2000
FIC 1650's
Flex Fuel
Precision 6765
Tial 44 Wastegate
Tial 50 BOV
Dual Intank FB 340s
AEM V2
AEM Wideband
Not sure if it will help, but I have pretty much the same setup but a GM 3 Bar map sensor. SNSR-03074. Cold start it revs a little high (2.5k) but then goes back down to 1000. I'm on 2000's though.
Old Feb 17, 2015 | 11:29 AM
sohc_mshue's Avatar
I have used a flashpro in conjunction with the aem v2 on these cars to get the idle nailed down right. I never had a high idle issue like you describe though even with running a 4 bar.
Old Feb 20, 2015 | 10:15 AM
9KRDLIN's Avatar
Jin is correct, as is AEM.
The Series 2 for your car uses the factory ECU to control the throttle blade. With you changing the MAP sensor to a 4 bar, the signal is no longer reading what the factory ecu wants to see. Put in the stock MAP, and change the tune to a stock MAP sensor in the settings, and the problem should go away. Then you should do like Jin did, and add an external/2nd MAP sensor to read actual boost for the AEM, which is controlling the Fuel and ignition. Jin also has a MAP clamp so the factory ECU does not see boost, and freak out, trying to close the throttle body.
Shoot me a PM if you have any questions.
Wade @ SOS
Old May 27, 2015 | 01:19 AM
uLmighty's Avatar
Did u ever figured this out?? I recently got my tune today on Aem v2 DWB my08. My idle is at 1.5k and my afr goes back and for from 10-16 on cold start... It goes away and stays at 13.6-14 after 2-3 min of idle. When I turn it off it does the samething even though is already been warmed. My temp gauge don't work neither. Can anyone help?
snitm
Dec 15, 2015 11:51 AM
Jjnormanyale
Jul 1, 2013 01:41 PM
kaissi
Apr 3, 2010 04:55 AM
indebt&lovinit
Nov 15, 2006 09:23 PM
waytooslow
Apr 24, 2006 08:04 PM
