Turbo S2000 doing donuts
Old Sep 20, 2006 | 08:58 PM
Scorpion's Avatar
Talking Turbo S2000 doing donuts
I thought you guys in the FI section might enjoy this.
http://videos.streetfire.net/video/835ef83...841009f5cc7.htm
Currently running 16psi...
Old Sep 20, 2006 | 09:37 PM
XclusiveAutosports's Avatar
Very nice! Hey Brian, what do you think about me running 9psi on stock compression? Good or bad idea?
Old Sep 20, 2006 | 09:44 PM
xviper's Avatar
I don't think you needed 16 lbs of boost just to do that.
Old Sep 20, 2006 | 11:15 PM
Scorpion's Avatar
Yeah probably not, but it makes it more fun
I ran 10psi on stock compression for a few months and didn't have any problems. Just make sure that you retard the timing a bit. Start with like 14-15 degrees and then advance until you find the sweet spot. If I remember correctly I was at 17.5 degrees at 10psi. Right now she's at 16 degrees at 16psi on a 2mm gasket. I could add another 2 degrees easily, but I'm tryingto keep the motor around for awhile
Old Sep 21, 2006 | 06:22 AM
Spoolin's Avatar
Wow, I am at 18 degrees at the top end on 6 psi and at 332 whp on pump gas! I can't wait to try 18 on 10 psi next week; I may hit 450 whp with it that way.
Old Sep 21, 2006 | 06:29 AM
Wow, please keep me posted with your results. I like your argument about the overall static compression still being lower with stock compression versus higher boost with 10:1 compression, it makes sense to me so i'm looking to turn it up to around 9psi.
Old Sep 21, 2006 | 08:35 PM
2 fast for u's Avatar
Awesome!!! I just watch it like 4 times in a row. Are you running the GT3082R already? At what RPM do you reach full boost? What about lag? Do you feel a lot?
Old Sep 22, 2006 | 02:25 AM
Scorpion's Avatar
Yes I am on a GT3082 right now with a .63AR. Planning on going to a .82AR in the near future. Full boost is right around 4800 if I remember correctly. Lag isn't too bad, only takes a couple hundred rmp to spool up when I go WOT above 5k.
Old Sep 22, 2006 | 05:48 AM
kenyellows2k's Avatar
is this with stock differential, very impressive burn out. I want to buy this rear end if its aftermarkt, if its stock that even better.
Old Sep 22, 2006 | 08:55 AM
passmans2kny's Avatar
i too am concerned about my diff bc im going turbo over the winter. did inline pro release their conversion kit? anyone runing it?
