Is a Turbo S2000 as a Reliable Daily Driver a Pipedream?
I used my turbo s2k at 400hp on 92 for about 6 months while I was trying to keep my debt low so I could buy a house. I will say the only real reason I stopped was because I didn't like to daily the S. I didn't stop because it was boosted. Now that I'm at 700hp, I'll drive it to work and back home as long as it's nice out without question. There is always something small happening but it's always minor and i'm typically prepared for it. But if it was my only vehicle, it would make me alot more nervous.
What are the opinions on torque dampers? I know they help a lot with vibration and keep the engine smooth for N/a guys, that may help guard against cracks and bolts backing out on log manifolds theoretically.
I already have one sitting in my garage but I'd need to modify the bracket to make it fit. Worth the time/cash?
Originally Posted by Memo6453' timestamp='1460983187' post='23941327
I wonder if the mild SOS TS Max kit would work for a Daily ... that seems like a safe 380-400 whp turbo setup.
For one thing, there's less heat soak and vibration to worry about which is a huge problem with turbos. Supercharger kits are also generally a bit more straightforward to install, so the likelihood of something going wrong in that process is a bit lower. Linear powerbands also tend to be more forgiving on the drivetrain components.
I DD my turbo AP2 with over 100k on the odometer. Granted it's only a Greddy kit but I'm satisfied and I'm not looking to break any land speed records. The only problem so far is the hardware connecting the snail to the manifold keeps backing out but I consider that minor in the grand scheme of things.
I also think the allen/hex socket head bolts are slightly less likely to back out as well than standard bolts. You can pick them up cheap at Home Depot.
Funny you mention the Nordlock washers. I just put some in this weekend along with some high temp thread locker so hopefully this solves my problem. I wish I could use bolts instead of studs but there's almost no clearance between the turbo and manifold flange, I could barely get a nut in there. We'll see how it goes, last resort will be to weld the turbo to the manifold lol.
Possible? Definitely. Do most people do it the 'right' way? Not that I have seen. Most people ignore thermal management issues; i.e. having extremely hot exhaust bits next to things that can't take much heat (getting rid of the factor header heat shield and not replacing it with some to protect the fuse boxes, battery, A/C line, VTEC solenoid, motor mount, etc). The cooling system should also be upgraded (radiator, oil cooler, vented hood). The front opening of the bumper is sized for enough airflow for a 240hp engine. Guess what happens when you try to make double the power? The front opening isn't really big enough anymore for sustained power. Look at any turbo car from the factory (Evo, STI, BMW, Focus ST, GTR, 911 Turbo) and they all have a clean airstream to the radiator separate from the airflow going to the intercooler. Sure, quick bursts up and down the street should be no problem, but not keeping your foot in it for any sustained amount of time. Plus people stuff massive intercoolers taking up the entire opening which of course reduces airflow (and adds hotter air on top of that) to the radiator, etc. Many people also try to cheap out on components. Instead of using braided stainless oil lines, they'll use rubber, stuff like that.
So can you turbo a S2000 and make it reliable? Of course. But it's not easy and most people don't spend the money to do it right.
I don't work on my car other than the basics. I would of never even gone turbo if I didn't know someone who i trust 100% to work on my car. Labor alone from a shop would of cost me $8k for them to install my turbo kit. I got lucky and through Autocrossing with my local car club found someone who knows how to pretty much fix anything on a car. We agreed on a deal for him to work on my car, and volia!!! I supplied all the parts for the car and he installed them. About 3 months later......bam!! 526whp/358wtq!! I wanted the best of the best parts for reliability. He did a lot of extra miscellaneous things to make the car even more reliable. Safety wire the turbo bolts/relocated fusebox,battery etc.
My point is...if you don't do the work yourself or have a ton of money for the up keeping or know someone who you trust to work on your car for less than shop rates, it's going to be tough.
