Turbo S2k & boost creep
Old Feb 28, 2008 | 11:08 AM
synapse's Avatar
Default Turbo S2k & boost creep
I keep hearing about more and more S2Ks that are turbo and running into boost creep. And this is not just on log vs tubular manifolds either. I've heard this with GT30Rs and even T3/T4 setups.
I want to understand this problem a little bit better.
If you have had boost creep issues, please post your setup, turbo, wastegate, manifold, etc.
Old Feb 28, 2008 | 11:28 AM
passmans2kny's Avatar
i'm not up and running but have see a lot of people having creep, i have the full race mani 2nd gen and some people are getting creep with them. so i guess this is for your 50mm wastegate? it is impressive im not gonna lie
Old Feb 28, 2008 | 11:50 AM
btstone84's Avatar
wtf is boost creep????????
Old Feb 28, 2008 | 11:57 AM
Quivers's Avatar
Banned
Its when you buy a huge turbo and a crappy little wastegate. You wont have boost creep if you buy properly matched components.
Old Feb 28, 2008 | 12:49 PM
Itchy Dick's Avatar
So you won't get boost creep on a standard Greddy kit then?
Old Feb 28, 2008 | 12:52 PM
synapse's Avatar
Nah, I'm just asking in general, I want to see the setups and combos people have that are producing the issue.
We have 2 people so far, that I've dealt with that have our gates that have fixed their issues, but with our 40mm not the 50mm
The problem is deeper than that. It comes down to fabrication sometimes, like a bad wastegate placement. But it is basically when your boost flatlines at say 10 psi, which is your target, and then it just keeps climbing to like 15, and you can't control it. Proper turbo matching can be a big contributor as well.
Old Feb 28, 2008 | 01:10 PM
PeanutButter's Avatar
full race mani
gt30
44mm tial
3 inch free flow exhaust
Old Feb 28, 2008 | 01:18 PM
synapse's Avatar
Buttter- Creep?
You know the fix is probably a 2.5" exhaust, right? I've tested it, and it works.
Old Feb 28, 2008 | 05:00 PM
rob!'s Avatar
your having boost creep with a FR manifold and 44mm tial? sounds suprising. Not doubting you though... what boost level is your target and what is it creeping to?
Old Feb 28, 2008 | 05:03 PM
Originally Posted by synapse,Feb 28 2008, 02:18 PM
Buttter- Creep?
I wouldnt drop down to 2.5 exhaust to fix it.
I have since sold the full race, upgraded to a built block, way more boost.
It will probably happen with the new setup, but wat can you do
Big creep, 7 psi spring, hitting 12 psi
