Turbo s2k braided lines
Old 04-22-2018, 06:39 AM
Carbon S2K's Avatar
Default Turbo s2k braided lines
Hi guys, I need to order my fuel lines. What would be best? 8AN feed/ 6AN return OR 10AN feed/8AN return? Is bigger better or can you go to big? I just don't want to do have any limitations down the line and need to do them again to be honest? The turbo I'm running is a (gen2 gtx 3582r) and will be installing the sos twin pump surge tank.
Thanks for the help
Old 04-22-2018, 09:55 AM
staylor725's Avatar
I went with -8 feed and 6 return, I was thinking -10 was over kill for my power goals. Here’s a picture of stock feed line next to -8 it’s a big difference.
Old 04-22-2018, 10:23 AM
AP1Chief's Avatar
-8 with proper pump and injectors will support 900-1000
Old 04-22-2018, 05:27 PM
Spoolin's Avatar
I went with -10/-8 but I'm on E85 and will be over 1k whp.
Old 04-22-2018, 06:24 PM
AP1Chief's Avatar
I plan on making 9-950 with -8
Old 04-23-2018, 05:59 AM
Carbon S2K's Avatar
This is brilliant thank's guys, so really up to 900-1000 hp -8 is fine but -10 for 1000+hp
Does anyone know if there's a downside to having oversized lines? I was thinking more fuel not being used going back to the tank constantly
being heated up
Old 04-23-2018, 06:45 AM
soulicious's Avatar
Not sure what kind of EMS you have, but with AEM, you can make them staged so that the second pump activates at whatever condition you want.
Old 04-23-2018, 07:17 AM
Carbon S2K's Avatar
Oh I see, the staged pumps are a good point, but as the -10 lines will hold a larger amount of fuel even with staged pumps there will still be more fuel circulating to the engine and back to the tank? Or have I got this wrong? I just can't help but think there must be a good reason people go for the -8.
Oh is it dependant of what fuel your using? Is that rite you need more E85 for the same power level?
Old 04-23-2018, 07:19 AM
hatrickstu's Avatar
A -6 will be more than overkill for anyone on here. We have made 1,400+whp on E98 with a -6 feed.
Old 04-23-2018, 07:47 AM
soulicious's Avatar
Just keep it simple and go -8/-6. Plus, any larger will be a pain when installing.
Quick Reply: Turbo s2k braided lines
