Turbo Setup
Old Jun 24, 2012 | 07:01 PM
  #41
ScorpionT's Avatar
Originally Posted by klopot_s2k
Yes i have decided that i will be going with the pfab elm mani with 3 inch downpipe & dumptube, the gtx3076r, ID1000cc and everything else stated on my first post. Now i have to make decisions on the exhaust and using e85 or 109 octane which is sold a couple miles away from the house. Cant wait to start this build!!!!!!!!!!
Plan your fuel type then get the injectors. ID1000s wont make the power you are looking for if you run E85, and you would need to step up to the ID2000.
Old Jun 24, 2012 | 08:50 PM
  #42
godmachine's Avatar
Originally Posted by s2knoob89' timestamp='1340460119' post='21805389
A 6262 will easily meet your power goals. I have around 2k miles on my JB 6262 and still has zero shaft play with no smoking.
As far as your parts list everything looks good besides your injectors. Pick up a set of ID 1000cc injectors and don't forget about a map sensor I reccomend the SOS 3 bar. Stick with the OEM head gasket unless you like changing the 3mm gasket every oil change. You most likely will not make 500whp on pump gas. Our engines are limited to around 450whp on pump with a efficient setup because of the 11:1 compression ratio.
Did you build yourself or go to a shop? Im second guessing myself now on this pte 6262, and what do you think of the pte6266 and turbonetics??? I feel like garret it played out, every1 and there mom has a GT
Garret is played out because everyone and there mom has a gt frame turbo? WTF are you 13 and trying to be cool and different ? The reason everyone uses GT turbo is cause it works and works for a LONG time. OE vs some company just doing whatever they feel like to make power for a short time.
PTE will make power but it will be short lived .
Turbonetics from what im told sells used turbos cleaned up as new. Reason behind them being so good with warranty
Old Jun 25, 2012 | 01:02 PM
  #43
GoOn3's Avatar
Originally Posted by DFWs2k
Return vs return less
Interesting, I didnt know that! I wonder what prompted the change?
iAhmad
Dec 4, 2012 10:20 PM
S2Race
Jul 25, 2009 06:43 PM
Enthralled
Dec 20, 2008 08:18 PM
nvmyap1
Nov 18, 2008 09:47 AM
SPECIAL-OPS-S2K
Apr 6, 2007 04:48 PM
