Turbo in the summer heat
Old May 10, 2007 | 04:04 PM
kenyellows2k's Avatar
Default Turbo in the summer heat
I had my turbo for almost 9 months now, summer is coming anyone went through it with a turbo whats really a must in stop and go traffic I was thinking invest in a vented hood ?. I still have stock radiator, I have external oil cooler.
Old May 10, 2007 | 04:46 PM
ChefJ's Avatar
A vented hood is a good start. Look into wrapping your downpipe and possibly your turbo.
Old May 10, 2007 | 05:32 PM
Reborn56's Avatar
Just leave your fans running all the time
Better a burnt out fan then replacing a motor because of heat
My friend leaves his fans running all the time
It took his under the hood temps from 210 F to 190 F
Atleast do it for the summer.
Old May 10, 2007 | 05:37 PM
waltk88's Avatar
Isn't winter the riskier season, with cold air and boost spikes?
Old May 10, 2007 | 05:39 PM
I will do the fan, something I can do right away thx. I will wrap everything yep.
Old May 10, 2007 | 05:40 PM
Reborn56's Avatar
Dude after tryin to work under the hood of a LoveFab kitted s2k
Id rather the winter then the summer.
I couldnt even breathe under that hood it was SO hot!
Mines is gonna be no different tho =(
Marcus
Old May 10, 2007 | 05:53 PM
BulldogS2's Avatar
how and what do you wrap the turbo with?
Old May 10, 2007 | 05:56 PM
ChefJ's Avatar
Turbo blanket. They also make a thermal wrap for the downpipe.
Old May 10, 2007 | 08:31 PM
Spec_Ops2087's Avatar
*shrug* I just have a vented hood and temps are acceptable by any means so far.
Old May 11, 2007 | 12:35 AM
afwfjustin's Avatar
I'm having some heat issues driving around in stop and go. I think venting the hood is going to be a gigantic help. I'm running the stock radiator and stock oil cooler and a lovefab manifold, so yes, it's very hot. We just installed a metal heat shield to protect my fuse box as the plastic was getting so hot it was tacky to the touch, but after the shield the plastic stays much much cooler.
I will be putting thermo sleeve on my rubber hoses and termotec tape around the smaller wires and such, as well as the vented hood. Heat is not something you want to mess around with, so I keep my drives short and I always let the car idle at least one minute with the hood open when I get out of the car.
