Turbo Update
Old May 24, 2009 | 10:46 AM
Shftat9k's Avatar
Marc, you will not need the map sensor for now. You can go up to 11psi with the stock map sensor. That is the limit though. When you are ready to make more power get a pnp map sensor. Omni power, Hondata, and SOS offer one. I will pm you about the wastegate.
Martin
Old May 26, 2009 | 04:47 AM
waytooslow's Avatar
than if your trying to do more than 11psi , if i were you i dump that RFL bov, it leaks, and get like a hks ssq. i also recommand you get a headgasket if you dont plan on building your engine
Old May 26, 2009 | 06:08 AM
dsddcd's Avatar
Are you using the tubular or cast mani? Based on your information you may be happier with the Hondata over the AEM. Also if you may want to look at using a set of 1000CC injectors over the 750
Old May 31, 2009 | 06:42 PM
combats2000's Avatar
Here is what came in the mail so far.
Old Jun 5, 2009 | 10:07 AM
more stuff. car is taken apart. and things are starting to go on!! more pics to come.
need bolts here, hoses there. $$$ is climbing higher and higher.
Old Jul 28, 2009 | 08:24 PM
update
Old Jul 29, 2009 | 02:38 AM
02serv's Avatar
combat how much did you spend total on putting together your kit
Old Jul 29, 2009 | 05:46 AM
s_d2k's Avatar
looks good..
stock exhaust??
Old Jul 29, 2009 | 08:54 AM
about 4k with ems and guages all brand new. dealer pricing
Old Jul 29, 2009 | 08:55 AM
Originally Posted by s_d2k,Jul 29 2009, 05:46 AM
looks good..
stock exhaust??
invidia 70mm dual w/testpipe. 3inch down.
