unknown reason for boost cut?
Old May 24, 2012 | 02:30 PM
bmccoy300ex's Avatar
Default unknown reason for boost cut?
so my car is almost finished with only one issue. when i come in to boost at 6500rpm(no matter what gear) it seems like the car hits antilag and pops and sputters, also getting some compressor surge when i let off. I run a series 1 aem ems with a mac solenoid. ecu was unplugged for about 6 months if that matters? im also running dual pumps with fullblowns setup
I know the boost solenoid has the vacuum lines running to it properly. But which pins on the d plug should be used? and can the wires have to be a certain way?
car runs great besides this issue and i did a full shave and tuck so i knew i was bound to have at least one issue to come up with all of the rewiring.
Any help is appreciated thanks a lot
Old May 24, 2012 | 02:43 PM
DFWs2k's Avatar
Wastegate lines still on?
Sent using free Tapatalk - Android FTW
Old May 24, 2012 | 02:44 PM
yep i have them run properly
Old May 24, 2012 | 03:39 PM
spectacle's Avatar
Can you post a log?
Old May 24, 2012 | 03:41 PM
Can you post a log?
dont have a laptop with the software yet
Old May 24, 2012 | 05:38 PM
Anyone else?
Old May 24, 2012 | 10:52 PM
seoul2k's Avatar
was the car down for a long period of time?? if it was i had a similar problem to urs. i have an ap1 with an inline pro stage 1 kit on it and at around 62-6500 i would hit a wall and it wouldn't let me go past it. if i babied it into the throttle it would be fine.
My problem ended up being that the fuel pump went bad. I ordered a new walbro 255 from amazon, (ebay there are a lot of fakes) and installed that with a new filter that goes on the fuel pump, and the actual fuel filter assembly that the pump sits in. After i changed that it went back to being normal. LIke u said driving it under 6500 rpm it would drive like it was stock. no problems what so ever, but after i hit 6500 it would die on me.
Old May 25, 2012 | 04:49 AM
Car was down for about 6 months. I had one 255 before and I just bought another one. Old pump was stored in a full tank of fuel while all of the other work was done. I'm gonna get a log here soon. But thanks for the help man. Hopefully that isn't my problem cause that dual hanger is a bitch to install haha
Old May 25, 2012 | 04:58 AM
camuman's Avatar
is car tuned? possibly overboosting? maybe 2 step set up wrong.
Old May 25, 2012 | 05:43 AM
It is tuned but it ran good before I did the shave and tuck. Can an aem forget the tube over time or something I'm lost when it comes to tuning
