Upgrade Fuel Delivery - HELP!
Old Aug 23, 2005 | 04:40 AM
s2knky's Avatar
Question Upgrade Fuel Delivery - HELP!
I'm running N/A Setup - but since you FI guys have to upgrade fuel systems - I thought I'd ask here.
I've been posting for weeks about this with no help - HELPPPPP!!!!
I need somewhere clean to tap into the fuel for my ZEX wet kit.
There's nowhere on the rail to go into.
The fuel line isn't exactly tappable above the intake manifold either.
Is there a fuel pressure regulator or fuel rail - or combo that will give me somewhere to draw fuel from without robbing my injectors ?
I don't want to cut fuel line if I don't absolutely have to.
Big race this weekend - need help!!!!!!
Thanks!
Old Aug 23, 2005 | 02:06 PM
Spaceman Spiff's Avatar
There is a company called BDL industries that looks strangly like the STR product line. They're pretty new and I have no experience with them but they do sell the only aftermarket fuel rail for the S2K I've seen.
BDL Industies Product line
This should give you exactly what you need.
P.S. stay away from any kind of tap into your FPR for a secondary fuel source.
Old Aug 23, 2005 | 02:14 PM
Spoolin's Avatar
Didn't see any prices. Any idea on how much they are?
Old Aug 23, 2005 | 02:23 PM
You'll have to contact them.
Old Aug 23, 2005 | 04:35 PM
s2knky's Avatar
they're the same thing as STR - however, theres a clause that says you have to modify the s2000 fuel line to work with the rail.
GRRRR....someone on here has had to have put a zex kit on their s2000.
Old Aug 23, 2005 | 09:50 PM
folex187's Avatar
Why can't you tap the fuel rail? You could use the spot that this gauge was mounted:
Old Aug 24, 2005 | 03:22 AM
s2knky's Avatar
My main concern is robbing the last injector there of fuel. Fuel gauge doesn't exactly steal the flow from the line, just holds the pressure. When I'm spraying - the last thing I need is one of the cylinders going lean on me....
Old Aug 25, 2005 | 05:35 AM
s2knky's Avatar
I have successfully installed the Zex 82021 wet kit.
If anyone would like assistance with this feel free to PM or email me.
I didn't get any help on here with several postings.
I'm putting these words at the bottom to help someone with the search, if they are looking for assistance.
Zex nitrous kit install
Zex fuel
nitrous fuel
zex TPS
zex Throttle Positioning Sensor
zex wiring
zex fuel supply
install zex
install nitrous kit
Old Sep 16, 2007 | 04:36 PM
jstriker's Avatar
So are there any updates on what fuel rail would allow me to tap my ZEX wet kit into?
Old Sep 16, 2007 | 04:50 PM
5thelement's Avatar
i tapped my stock fuel rail and im boosted without robbing the injector of fuel. Aftermarket rails have taps already for fuel gauge and nitrous all depends on budget
Bdl fuel rail-120-160
inline pro fuel rail-250
either one work good
StedFast
Nov 4, 2016 09:34 AM
99SH
Jul 11, 2012 01:25 PM
JuicedS2K
Jul 13, 2010 04:26 PM
MugenAP2
May 20, 2008 01:16 PM
ItalianBucwheat
Aug 21, 2002 12:15 PM
