Upgraded pcv for Ap2 valve cover?
Old Oct 1, 2015 | 12:24 PM
Habitforming's Avatar
Default Upgraded pcv for Ap2 valve cover?
What options are there for an upgraded pcv valve on an AP2 valve cover? I've seen mention of going to a Supra pcv on AP1 engines, but I assume that won't work since the AP2 pcv screws in. Has anyone tested the AP2 valve's resistance to boost pressure?
Old Oct 1, 2015 | 01:40 PM
chefs2000's Avatar
My supra is just shoved into a I believe 1/2in tubing
[attachment=85739::]
Old Oct 1, 2015 | 02:53 PM
Are you saying it's the one screwed into the valve cover, or its inside the tubing?
Old Oct 1, 2015 | 02:57 PM
chefs2000's Avatar
I left the one in the valve cover and put a supra one in the tubing coming off of it
Old Oct 1, 2015 | 03:03 PM
Chuck S's Avatar
What's to upgrade on a PVC valve? OK I'm seeing you're boosted.
-- Chuck
Old Oct 1, 2015 | 03:33 PM
lleron's Avatar
I did the same exact thing. Just cut the factory intake manifold->valve cover tube and put the supra PCV inline.
Old Oct 1, 2015 | 03:45 PM
beechx1's Avatar
Why upgrade the PCV valve?
Old Oct 1, 2015 | 03:46 PM
I'm totally not seeing it in chef's pic, lol
Is it the mkiv ('93-98) supra pcv that we use?
Old Oct 1, 2015 | 03:48 PM
Ours aren't designed to withstand positive manifold pressure, allowing them to leak pressure into the crank case, which in theory will rob some power.
Old Oct 1, 2015 | 03:54 PM
beechx1's Avatar
Hmmm... I'm only making 13.5 PSI with a C38-91 blower. I would expect more. Maybe my PCV is leaking. I'll cap it off and make a run to test it.
