Upgraded pcv for Ap2 valve cover?
Old Oct 1, 2015 | 04:42 PM
chefs2000's Avatar
Originally Posted by Habitforming
I'm totally not seeing it in chef's pic, lol Is it the mkiv ('93-98) supra pcv that we use?
you can't see it .. You literally stuff the whole thing in the tube that's coming off the valve cover
Old Oct 1, 2015 | 05:07 PM
Habitforming's Avatar
Ohhh, ok. Good thing you posted a pic then
Did you hollow out the oem pcv, or just leave it in tact?
Also are you using a 3rd party valve, or genuine Toyota?
Old Oct 1, 2015 | 05:08 PM
Originally Posted by beechx1
Hmmm... I'm only making 13.5 PSI with a C38-91 blower. I would expect more. Maybe my PCV is leaking. I'll cap it off and make a run to test it.
Have you made/bought a boost leak tester and checked all of your couplings? I can't remember your mods. If you have a lot if upgrades, your boost will be lower than a fully stock setup like mine.
Old Oct 1, 2015 | 05:11 PM
lleron's Avatar
Originally Posted by beechx1' timestamp='1443743116' post='23763770
Why upgrade the PCV valve?
Ours aren't designed to withstand positive manifold pressure, allowing them to leak pressure into the crank case, which in theory will rob some power.
Basically you can pressurize the crankcase with the stock PCV. This can rob some power as well as cause things like the dipstick to pop out and potentially cause blowby. For <$20 I figured it was cheap insurance.
Old Oct 1, 2015 | 05:58 PM
beechx1's Avatar
Yes I have made a boost leak detector. I have used it to find and fix several small leaks. My car is stock except for a TP. I also have a catch can connected to the valve cover vent. The catch can is vented to atmosphere through a small filter.
Old Oct 1, 2015 | 08:14 PM
chefs2000's Avatar
Ohhh, ok. Good thing you posted a pic then <img src=/wink.gif' class='bbc_emoticon' alt='' />' /> Did you hollow out the oem pcv, or just leave it in tact? Also are you using a 3rd party valve, or genuine Toyota?
Lol yea the pic helps .. ill post a close up of that tube tomorrow so maybe you can see through it lol..Left stock intact and got a supra pcv from autozone
speedstar808
Dec 6, 2012 09:35 PM
jyeung528
Jul 20, 2010 09:28 PM
speedstar808
Feb 13, 2009 09:28 AM
Bigeggroll
Oct 19, 2007 07:47 PM
TryPsi41
Aug 1, 2007 01:08 PM
