Vacuum at idle?
Old Apr 21, 2006 | 10:40 AM
SCA S2K's Avatar
Default Vacuum at idle?
What are you guys reading for vac at idle?
Also I get a little bucking in first gear sometimes any ideas?
the car:
Comptech w/cooler.
FMU
440 injectors.
Comptech header.
T1R test pipe.
Apexi exhaust.
HKS bov.
Clutchmasters st. 4 and flywheel.
Thanks.
Old Apr 21, 2006 | 10:47 AM
Sideways's Avatar
Do you have an EMS for the 440s?
Old Apr 21, 2006 | 11:00 AM
SCA S2K's Avatar
Have the Comptech ESM.
Also a VAFC 2 that is hooked up but not running anything.
When it was dyno tuned apparently it didnt like
the VAFC and the Comptech unit together (this is what i was told)
I was planning on pulling the VAFC alltogether and eliminating it from
the system.
Old Apr 21, 2006 | 12:13 PM
xviper's Avatar
Vortech at idle, mine reads about 10 to 12 psi vacuum.
Your "bucking" is a function of your clutch control and has little to do with any fault of the car.
Old Apr 21, 2006 | 12:18 PM
SCA S2K's Avatar
I have about 20-25 at idle.
more of a stutter than a buck as I
have stated above. Pretty sure not clutch related.
Old Apr 21, 2006 | 12:31 PM
xviper's Avatar
Your vac at idle seems a bit high compared to mine. Maybe just a difference in gauges.
Not sure what you mean by "stutter", but "bucking" on this car is a well known phenomenon that can be bypassed with a little foot work:
https://www.s2ki.com/forums/index.ph...opic=380314&st
http://forums.s2ki.com/forums/showthread.p...ghlight=bucking
Old Apr 21, 2006 | 12:49 PM
SCA S2K's Avatar
Thanks Xviper.
I read the other posts with the bucking thing..
This is my situation, so thanks for the links. I didnt even search
for the problem. I assumed that it had something to do with the vacuum.
Apparently the old saying about assuming holds true.
spa2121
Jun 15, 2006 09:10 AM
ckautt
Jun 28, 2004 05:44 AM
pjonkheer
Apr 21, 2004 07:20 AM
bgbfflochp
Mar 22, 2003 09:19 AM
