Vacuum Lines
Old Jul 21, 2008 | 01:54 PM
blueap2's Avatar
Default Vacuum Lines
I need help running my vacuum lines. So far this will be my setup.
Top port of wastegate to electronic boost controller valve, from valve to compressor housing. From boost controller unit to fpr line.
My question is, where should I tap to get a source for the side port of the wastegate and for my bov?
Thanks!!!
Old Jul 21, 2008 | 04:22 PM
neeman77's Avatar
I tee'd into the line from the intake manifold to the FPR. This shows the real pressure that is reaching the motor after pressure losses through the intercooler (which should be minimal). If you would like, you can also run off of the compressor housing of the turbo. For the blow off valve I used a vaccum line that I removed for the EGR system but had to put a clamp on the hose since the nipple on the manifold was slightly too small.
Old Jul 22, 2008 | 11:26 AM
blueap2's Avatar
spoke to greddy and got a response. please close.
dsddcd
Jun 1, 2019 07:53 PM
Titounais
Sep 23, 2016 01:47 PM
realblag
Jul 22, 2010 06:17 PM
boltonblue
Jun 14, 2009 07:11 PM
spoiled@21
Oct 8, 2005 04:36 AM
