VALVE SPRING FOR TURBO PROJECT
Originally Posted by MoMoSiR' date='Feb 3 2005, 05:40 PM
DO I NEED VALVE SPRING ON S2000 FOR TURBO PROJECT
APPROXIMATELY 500HP
THANK YOU
APPROXIMATELY 500HP
THANK YOU
AEBS said that valves with stock springs will float at greater than 18 psi . As a result, they upgraded my valves to the dual rate springs last year. Apparently, Chris (cjb80) didn't have any problems at 23 psi, but I'm not sure how many hours he put on those springs. As the springs lose some compression, there might be a greater chance of collision with the pistons at high boost. Before the dual rate springs were available, some engine builders substituted the stiffer exhaust valve springs on the intake side.
What are the problems with stiffer valve springs?
how much boost are you running atm yakrat?
have you found a solution to your traction problem yet?
I am running around 16-18psi at the moment and wheel traction is also a problem at high rpm even in my 255/35/18 SO3. The s2k is insane with the turbo.
I am running 22 psi on the track.
The traction is better on R compounds. I haven't mounted my 18" wheels yet. I plan on putting RA-1's on them.
The power is great (330 wheel torque at 22 psi). The stock S02's do break lose in 4th at 22 psi. I generally run the car at about 18 psi. I feel that the ATS differential has improved the traction some.
silverwagon
Sep 8, 2014 08:03 AM
riceball777
Apr 14, 2014 07:32 PM
