Variables when trying to achieve various HPs
Old Sep 15, 2012 | 10:32 AM
OHclassic's Avatar
Default Variables when trying to achieve various HPs
I realize this might be a general question to a highly varibled answer so thanks in advance for any insight you guys can provide.
* Once a turbo build has been choosen (all the parts), what major and minor variables can a tuner adjust via the EMS or other to set the HP/Tq levels and what are the major limitations reached before you have to swap out to upgraded equipment ? Use ~500 HP as a limiting factor for discussion purposes as that seems to be a common build for STOCK engines for many of the guys on here.
Thanks
Old Sep 17, 2012 | 02:01 PM
timg's Avatar
The parts combination is what makes the power. All good tuners (and all decent engine management systems) should come roughly within the margin of error of one another for a given dyno (for a given boost level). It seems like the majority of the time, if someone wants a number and can't hit it, there's something off in the parts combination (injectors too small, boost solenoid wired/plumbed incorrectly, turbo manifold too restrictive, bad spark plugs or coils, etc.).
Tim
Old Sep 17, 2012 | 03:10 PM
s2000Junky's Avatar
The nice thing about our motor is it has pretty unrestricted potential as it stands in stock form, the major contributors in output are going to be turbo/sc size, fuel delivery and exhaust. The stock motor is capable of flowing upwards of 800whp if you have the previously mentioned accessories in place.
Old Sep 17, 2012 | 03:27 PM
vduber's Avatar
It all really comes down to how much god likes you
Old Sep 17, 2012 | 04:11 PM
passmans2kny's Avatar
guess I'm on his bad side...
Old Sep 18, 2012 | 08:58 AM
OHclassic's Avatar
Tim
Thanks all for the comments, appreciated.
OK, getting specific as I'm expecting to get my ride back with following set up:
2001 F20 stock
Custom Manifold T3 Flanged (ram horn)
GTX-3076R (0.63 A/R)
Tial 44mm Wastegate
600HP Intercooler
Tial 50mm BOV
3" Downpipe / Dumptube
1000cc Injectors
Walbro 255
AEM EMS - Series II w/ Boost Control Solenoid
3" Exhaust (no cat)
Methanol injection (running 93 gas)
** My goal was 500whp w/ max torque.....anyone see any problems with achieving the goal assuming the tune is good and no other major issues ?
Thanks !
Old Sep 18, 2012 | 09:11 AM
s2000Junky's Avatar
You may find that your pushing that 255 and should go with a larger pump like a 340 as well as a adjustble pressure regulator. With meth injection your going to be able to push that turbo 22+psi and near 600whp.
Old Sep 18, 2012 | 09:33 AM
OHclassic's Avatar
Good suggestions, appreciate it !
* With those mods and possible increase to 600whp in future....would I start pushing the limits of the stock motor, diff & trans being dependable for a daily/weekend fun car (Not drag, road racing, etc....just having fun on weekends) ? I want to drive the car and not have it in the shop every time I decide to push the gas.
Old Sep 18, 2012 | 09:40 AM
s2000Junky's Avatar
I would stick to about 475-500whp. Still plenty fun, and you’re not pushing the motor and drivetrain to the ragged edge. Boost the motor 17-18psi, but use the water/meth injection as a cooling agent and safety barrier rather then a means to run massive timing increases, which you shouldn’t have to, to reach your power goals. Just be sensible and hopefully you have a good tuner.
Old Sep 18, 2012 | 10:08 AM
OHclassic's Avatar
Originally Posted by OHclassic' timestamp='1347989626' post='22020669
[quote name='s2000Junky' timestamp='1347988312' post='22020594']
[/quote]
Greatly appreciate the advice which is basically what my tuner said he was "OK" with for what I asked him to do/achieve. He was only going for 400whp until he suggested the meth kit to cool/add whp and still have safety barrier. He seemed quite cautious about going to far over 500whp but was just following how I wanted him to set it up.
Thanks again
WRCGooseS2K
Mar 31, 2015 03:36 AM
swifbboy
Mar 13, 2015 11:32 AM
connelly
Jul 14, 2007 05:49 PM
nsxinsac
Aug 12, 2005 12:44 PM
S2peed
Nov 25, 2001 07:39 AM
