Verifing Ignition Timing w/ Crank Position
First off, I was surprised that nearly no one checks the ignition timing in the EMS vs the crank position. With a good tune the base timing map would accomodate for a differential in the the anticipated and actual but there are portions of the tune where accuracty would yeild a better tune.On my last setup I was able to adjust the timing easily as I was not using the factory ignition. I have since removed the system so that I could do some testing on the factory system again.
Anyway, the only way I have figured our to test the timing is to pull the #1 coil and plug in a spark intensity tester then use my inductive loop from my timing light around the lead for the tester.
I have tried to use the coil signal wire but my light cannot pick up the signal. When I use the coil power wire I get a signal that is app 15 deg off of what I believe to be the correct position.
If anyone has a better way of testing I would be interested in hearing.
Well that was the road I was going down, but as you mentioned my method was only acceptable in a static position during idle. With my other ignition system I did both and had to adjust the sync position but there was no drift.
Thanks for the heads up
^ Yup just grab a spark plug wire small enough to fit onto the spark plug and then pull the rubber boot off the other end and stick it into the coil pack. The coil pack just sits on top of the valve cover with the wire firing the plug. Put your pickup on the wire between the spark plug and the coil pack.
