vortech aftercooler
Old Aug 21, 2007 | 12:36 PM
S_NeWb's Avatar
Default vortech aftercooler
hi i am about to move to Massachusetts, and i am supercharged (aftercool).
Doesnt the water freezes under freezing temperture with the vortech setup? I dont want it to bust under freezing temperture. Is there something i can do? like antifreeze?
Old Aug 21, 2007 | 01:05 PM
d-j's Avatar
d-j
What water/coolant mix are you using?
Old Aug 21, 2007 | 02:52 PM
Slows2k's Avatar
As long as you are using an engine anti-freeze it will not. If you are using water, you can rupture the aftercooler, radiator and reservoir.
Old Aug 21, 2007 | 08:24 PM
S_NeWb's Avatar
right now i am only using water. so whats best to use?
Old Aug 21, 2007 | 08:55 PM
CourageOO7's Avatar
Add antifreeze man...treat it like a regular radiator...especially when temps drop
Old Aug 21, 2007 | 10:33 PM
05TurboS2k's Avatar
remember water does better cooling but anti-freeze keeps it thawed..... mix em, probably water-wetter is safe to run, anyone see why it woudn't be? Engine Ice maybe even?
Old Aug 22, 2007 | 02:53 AM
mrsteve's Avatar
Water-wetter is most certainly safe for the system. Although it probably has the same effect on efficiency as regular engine coolant so I'd just pick up your favorite coolant and flush the system. 50/50 mix should be fine.
Old Aug 22, 2007 | 04:29 AM
S_NeWb's Avatar
thx guys. it dont get that cold here, but it will in Massachussetts.
Old Aug 22, 2007 | 07:36 AM
bigworm's Avatar
I live in new york, so I put 50/50 water and antifreeze just like you would in the radiator in my vortech. The antifreeze may also help corrosion inside the coolant system.
Old Aug 22, 2007 | 04:46 PM
TheCarGuy2021's Avatar
Let it freeze! That's gotta lower intake temps by at least another ~50 degrees!
Add some coolant/antifreeze.
KillerCom
Jul 9, 2014 08:51 AM
jordannn93
Jul 23, 2012 05:48 AM
dammitjim
Sep 25, 2010 07:02 PM
9kFever
May 20, 2008 03:25 PM
F1s2000
Oct 3, 2003 03:59 PM
