Vortech Belt Snapped off - How to Replace quickly?
Old Jan 17, 2017 | 12:17 PM
  #21
Dreaming_S2k's Avatar
Originally Posted by RolanTHUNDER
Doesn't look like an easy, 20 minute job no thanks to Vortech putting the lowest spacer of the bracket on the inside of the belt's route... oh man, why??? Lol
I agree with this 100%
It's the reason Vortech wasn't my first choice but...deal was too damn good.
Old Jan 19, 2017 | 07:06 AM
  #22
RolanTHUNDER's Avatar
My friend and I couldn't DIY after all. It was too difficult. Fortunately a really good mechanic who races Hondas and works on so many sorted me out in less than 3 hours so my boost is back! New belt on and she's boosting epic
Apparently those spacers in the way are very important as they prevent the blower from cracking the timing chain cover or head itself while in boost. It twists while boosting so those spacers keep it steady and dampen load on the timing chain cover itself.
Old Jan 22, 2017 | 06:40 PM
  #23
Originally Posted by bruthaboost
I know everyone has different levels of mechanical comfort, but don't let removing the blower assembly intimidate you.
1. Remove aftercooler from blower
2. Remove serpentine belt: use a 14mm box end wrench on the tensioner pulley.
3. Remove vtec solenoid: 3 allen head bolts.
4. Remove the two 8mm allen head bolts at the cylinder head.
5. Remove the lower bracket's 10mm nuts. There are two of them.
6. Remove the idler pulley bolt and spacer. Make sure you don't lose the back spacer from the idler pulley. It can drop when you remove the pulley.
7. Remove the 17mm? bolt holding the blower bracket to the exhaust side of the cylinder head.
8. Pull blower assembly from the block.
When re-assembling be mindful of the vtec solenoid rubber gaskets (you have two of them). I like to have one hand as a precaution. You bust it, you are dead in the water. It's easy to pinch and cut them on the bracket and cylinder head edges.
Hope this helps.
thanks for the detailed steps. Unfortunately I couldn't DIY even though a friend and I really tried. Problem solved now though
Old Jan 24, 2017 | 09:33 AM
  #24
tkeyyy's Avatar
Originally Posted by Singh_snisen
Leave belt off. Have fun na. All the superchargers have problems with belt snapping and slipping. The vortech and comptech kits r known for this. The sos and kraftswerks kits r superior but imo the kraftswerks is a little better because u get more hp for ur money. And aesthetically looks better imo.
all superchargers? yes. specifically vortech and comptech? no.
remember, the only 2 carb legal kits are comptech and vortech. that's why people get them. you can still make decent power off of them, but not as efficiently as SOS or kw. but beware of kw since they've been having a lot of issues with their pulleys on their v2 kit.
Hope this helps.
haha im guessing you installed the kit yourself? i installed mine, but i don't remember it down to details like this since i've only done it once.
Old Jan 24, 2017 | 10:46 AM
  #25
Singh_snisen's Avatar
^ vortech and comptech slip more when all brand supercharges are making 400whp. Kw I think r already making a v3
Old Jan 24, 2017 | 11:30 PM
  #26
oh I hope my kit doesn't slip at all for a long time. This belt change debacle was stressful lol.
Old Jan 25, 2017 | 06:53 AM
  #27
put some super glue on the belt.
Old Jan 26, 2017 | 04:59 AM
  #28
bruthaboost's Avatar
Yes to install and I have had it off/on more times than I can remember with mods:
Upgraded blower trim.
Multiples pulleys.
Up-sized crank pulley.
Old Jan 28, 2017 | 07:38 AM
  #29
No thanks
Old Jan 30, 2017 | 02:38 PM
  #30
tkeyyy's Avatar
remember, can't pass smog without a carb legal kit
i hope their v3 isn't as troublesome as the v2.
