Vortech Crank pulley
Old Mar 5, 2014 | 01:32 PM
APoner's Avatar
Default Vortech Crank pulley
Since there are a good amount of us running SOS and comptech supercharger kits, I was wondering if anyone has ever ran a Vortech crank pulley.
http://www.ebay.com/itm/Vortech-4HS0...85afcb&vxp=mtr
Since they discontinued the kit from vortech I've seen a bunch of stuff go for sale on ebay. I spotted this and was wondering if anyone has tried it.
I wanted to go down to a 3" pulley but I've read that some people have belt slip issues. This might help in getting the same boost pressure with a bigger blower pulley for more wrap.
I tried looking for a picture of just the crank pulley but i cant find one.
Any thoughts?
Old Mar 5, 2014 | 05:47 PM
99SH's Avatar
You cant use the Vortech underdrive pulley on the SOS provided crank pulley. The offsets and bolt pattern are different.
Old Jun 17, 2014 | 02:33 PM
faxter18's Avatar
I'm missing the crank pulley and modified damper for a Vortech V2 kit for AP1. The vendor above said they do not have these, and Vortech said that they do not sell these any more. Vortech advised to see if the SOS modified damper would work on the stock OEM crank pulley. SOS said they would be happy to sell one to me but can't guarantee it will fit. Anyone have any success for replacement crank pulley and modified damper?
Old Jun 17, 2014 | 04:16 PM
bruthaboost's Avatar
You can have ASP in texas make you a replacement. They may have one already "spec'd" for you. I know they made a 7" vortech pulley for me last year. You could ask them to make you a 6.5" version of what I got.
Old Jun 17, 2014 | 04:26 PM
faxter18's Avatar
Thanks, I spoke to them and they said they could do it. Is 6" or 6.5 the OEM size of the modified damper? How did the 7" pulley work out for you?
Old Jun 18, 2014 | 03:46 AM
The original vortech adapter is 6", however if you EVER think you're going to want more boost (and everyone eventual does), I would get the biggest one you can fit easily. I know 6.5" fits no problem. I'm pretty certain 6.75" will fit too, but it'll be close, like take off your water pump pulley to the belt on close. What's the benefit of this? It lets you "size up" the vortech blower pulley a half inch (or more depending on how much bigger your go) so less potential belt slip-you can stay over a 4" blower pulley. I went with 7" crank pulley because I was shooting for 18 psi and didn't want an absurdly little blower pulley. It works perfectly. I had to down size the water pump pulley though.
hth
Old Aug 21, 2021 | 06:59 AM
RolanTHUNDER's Avatar
hth
So will the 6.75" ASP pulley clear the stock water pump pulley or is it actually going to be too close for comfort?
Old Jan 20, 2022 | 07:48 PM
Sideways's Avatar
Have ASP make you a water pump pulley that goes with the crank pulley.
Old Jan 30, 2022 | 12:55 AM
I had a new larger than stock 6.5" crank pulley made by ASP Texas for my Vortech V2. They also made a fine supercharger pulley for the blower itself so I recommend them
Road racer
Nov 1, 2012 01:13 PM
boszyen
Jul 13, 2008 10:09 PM
martus2k
Jun 3, 2006 11:41 AM
macspeed704
Dec 12, 2005 01:47 PM
jwkim
May 12, 2005 12:46 AM
