Vortech intake is amazing considering how
Old Jan 6, 2007 | 06:19 PM
Sideways's Avatar
Default Vortech intake is amazing considering how
While working out some of the things that are keeping my car incomplete I decided to take a good look at the intake. I had assumed it was 3-1/2 inches all the way from the filter to the snail. John Z had mentioned it was considerably smaller so I did some measurements while changing out the intake.
The actual Vortech intake is the black elbow inside the blue/red coupler.
Double click the picture for a close up. The Vortech intake narrows down to 3.1 inches.
Old Jan 6, 2007 | 06:29 PM
GrandMasterKhan's Avatar
yeah i noticed that as well.
I only had a vortec in my possession for a few weeks but it looks like a nice 3" carbon fiber elbow would be mad easy to make for it or aluminum.
Old Jan 6, 2007 | 06:50 PM
John_Z's Avatar
^ You'd want an ID of at least 3.50" to match the blower inlet. 3.75" is an oddball for aluminum piping so might as well slap on a 4" with a reducer. A composite material would be best to avoid heat transfer.
Like I stated to Phil, the ID of the stock elbow is a bit smaller which in and of itself is not a huge issue, but 4" piping allows you to use a filter with a larger surface area as well.
Old Jan 7, 2007 | 06:32 AM
Sideways's Avatar
I wanted to avoid the heat transfer into the tube so I am looking at coatings.
Old Jan 7, 2007 | 08:20 AM
Ray K.'s Avatar
why not make an airbox or at least a heatshield so you aren't sucking in hot air from the engine bay? I think there is way more to gain there than heat transfer from things that have to touch each other.
Old Jan 7, 2007 | 10:28 AM
John_Z's Avatar
I put in cold air ducting. It doesn't do much on the dyno but at speed it directs cool air to the filter area.
Old Jan 7, 2007 | 03:28 PM
helmet155's Avatar
I would like to see your IAT sensor readings with and without...
Any idea what the delta is?
Old Jan 7, 2007 | 08:01 PM
John_Z's Avatar
I did the ducting while I still had the stock SC airbox. Delta was 2-4*F and probably not worth the hassle of taking off the bumper and relocating the aftercooler reservoir to the other side. I already had the air horn installed from the NA days with an AEM V1 intake so all I really did was just add some ducting.
Skatethesea
Jan 9, 2023 11:21 PM
Japmuscle
Jun 12, 2012 12:54 PM
leo520
Nov 20, 2009 09:12 AM
el10034
Jul 22, 2007 01:36 PM
mase1
Sep 18, 2005 12:00 AM
