vortech S/C questions
Old Oct 12, 2008 | 11:16 AM
08s2000CRbackinblack's Avatar
Default vortech S/C questions
are there differences between the ap1 and ap2 mounting brackets for the s2000 vortech kit? someone is selling theres for the ap1 and was wondering if it would be compatible for my ap2? thank you for any intput
Old Oct 12, 2008 | 11:27 AM
Enthralled's Avatar
should be the same, but you will need other parts to make it work on your AP2.
Old Oct 12, 2008 | 11:50 AM
what different parts would be needed? just fuel system? and a piggyback? but the charger itself and the mounting plate should fit perfectly?
Old Oct 12, 2008 | 12:16 PM
bump^^^^ need to know by tonight if i want to get it or someone else will buy it!!! please help
Old Oct 12, 2008 | 12:18 PM
Enthralled's Avatar
yes and yes....you'll also need a pulley and belt. stock pulley is 4.5" @ 7.5psi on an AP2..the AP1 kits come with a 5" pulley. Also, you will need larger injectors as well.
Old Oct 12, 2008 | 12:19 PM
Enthralled's Avatar
after everything is said and done, it may come out cheaper if you go with a KW kit. Or look into the new Vortech kits for the 06+ cars.
Old Oct 12, 2008 | 12:23 PM
Slows2k's Avatar
Brackets are the same for all kits. 00-03 kits have 5" pulleys and no aux injector.
04-05 kits use a the 4.5" pulley and mount an aux injector in the aftercooler. The fuel/timing controller is different as well.
Old Oct 12, 2008 | 12:26 PM
Enthralled's Avatar
this is my kit. see the extra injector coming from the aftercooler.
Old Oct 12, 2008 | 12:28 PM
CooperS2K's Avatar
dont you have an 08? youre gonna dish out the same amount of cash so why not save the hassle and buy the KW kit?
Old Oct 12, 2008 | 12:39 PM
its off an 2003 so it would have the 5" pulley would that give me more or less than 7-8 psi? im geting this kit for $2000 so its a steal. what size injector should i get 550? i plan on goin with the AEM FIC for tuning and timing
