vortech S/C questions
Originally Posted by Enthralled,Oct 12 2008, 12:43 PM
the 5" pulley should give you about 5psi. Injectors are dependent on how big you want to go.
I'm running the RC550 injectors right now with a 4" pulley(10psi)...I should be maxing the injectors out right now. I'd get the 750cc injectors to give yourself room to grow..the price between them isn't much.
Originally Posted by 08s2000CRbackinblack,Oct 12 2008, 04:22 PM
if the 5" pulley would only give me 5lbs boost would the 4" pulley give me 10lbs boost or should i get an even smaller pulley? again would the FIC be sufficient for tuning this setup?
Boost can't be defined by just pulley size on a SC. Max boost on a 2.0L car is going to be different than a 2.2 because of the lower redline, as well as smaller displacement. Change the exhaust, use a air to air intercooler, all are factors in what the max manifold pressure will end up.
If you port the head, expect boost to decrease with the flow rate increase.
Moddiction
Nov 22, 2009 06:51 PM
