Vortech SCer
Old Oct 17, 2006 | 09:57 AM
civicguyinva's Avatar
Default Vortech SCer
I know this isn't exactly F/I, but I know that the supercharger guys can help me with this one.
I have a Vortech stock kit with a 100% OEM exhaust. I'm installing a AFR gauge and the shop called asking me some questions.
Is the header double walled?
If so, when they weld the part to the inner wall, will the sensor still be in far enough for an accurate reading?
Where do you have your sensor installed?
Shop says the best part to do it in is a 2-3 inch spot where the header goes from 2 -> 1. Is that where everyone has it?
Thanks!
Old Oct 17, 2006 | 05:11 PM
EK9MAX's Avatar
I jus tinstalled my bung in my testpipe.,......
it's about 4" behind the stock primary o2 sensor.... so i figured it would be ok....
Old Oct 18, 2006 | 11:58 AM
I don't have a test pipe though which means it has to go before the cat somewhere. I'm kindda shocked more people havent given responses. Maybe its too stupid of a question to bother answering?
Old Oct 20, 2006 | 02:55 AM
Bibbs's Avatar
Did you get a reply for this?
I'll be doing the same soon and would like to know.
Old Oct 20, 2006 | 05:01 AM
Nope. No one seems to know or no one wants to say.
Old Oct 20, 2006 | 10:59 AM
QUICK_AG's Avatar
Mike, are you looking to have the gauge permanent or are you just using the gauge to check your AFR?
Old Oct 20, 2006 | 11:26 AM
Dsgs2k3's Avatar
alright guys, you should put it right before the 1st o2 sensor in the header, this way you will get the most accurrate reading. if you put one in the test pipe it is not going to be near as accurate as the one in the header. hope this answer your questions
Old Oct 20, 2006 | 11:43 AM
EK9MAX's Avatar
Why does it make such a difference?
Old Oct 20, 2006 | 11:51 AM
QUICK_AG's Avatar
Hey guys, keep in mind he's running 100% stock exhaust. I guess you are wanting to drill a hole in the header to accomodate the AFR sensor?
Old Oct 20, 2006 | 12:47 PM
Dsgs2k3's Avatar
it doesnt make that much of a difference but it will be more accurate in the header, thats all. yours is still pretty accurate
