Vortech Supercharged AP1 MASE'D
Old Aug 3, 2008 | 02:02 PM
9kFever's Avatar
Default Vortech Supercharged AP1 MASE'D
Found the boost leak on Friday so I thought it was time to take it back to the dyno. Mase added a bit of fuel to my map to make sure it was rich if anything. The fuel scales are all correct, but the car is now running a bit rich. My PLX wideband is bugging out so data logging was not possible, and unfortunately the dyno wideband was broken. Probably would pick up a little more when we lean it out a bit.
I was the first car of the day. Do you guys know if the dynojet usually needs to be warmed up? My second run was 5whp more.
Vortech SC
AEM EMS 1052
Hondata 4 Bar Map Sensor
ASP 3.9" Pulley
RC 750cc Injectors
PLX Wideband
Berk 50mm Header
3" Headerback Exhaust w/ 3" resonator
Tech2 Spearco Front Mount Radiator
Mugen Thermo
Mugen Fan Switch
Hondata IMG
K&N Filter
4.57R Cryotreated Gears
Comptech Reinforced Diff
ACT Clutch and PP
Comptech Lightened Flywheel
MASE tuned.
383.5whp/223.2wtq DynoJet
Video:
http://upload.streetfire.net/video/Vortech...rged_175203.htm
A c5 z06 with full exhaust and Ram Air intake put down 375whp.
Old Aug 3, 2008 | 02:10 PM
Danks2k's Avatar
Pretty much the same as my setup. Nice numbers. How much boost were you seeing?
Old Aug 3, 2008 | 02:11 PM
9kFever's Avatar
According to the defi about .95 bar. What did you dyno on?
Old Aug 3, 2008 | 02:13 PM
Danks2k's Avatar
Jeff Evans Dynapack
Old Aug 3, 2008 | 02:14 PM
9kFever's Avatar
Originally Posted by Danks2k,Aug 3 2008, 02:13 PM
Jeff Evans Dynapack
Nice! I need to see my damn AFR's. My bumper was clean before I left home and pretty black around the muffler after.. After the run you could smell the fuel.
Old Aug 3, 2008 | 02:15 PM
Danks2k's Avatar
Luckily my bumper is already black haha.
Old Aug 3, 2008 | 02:16 PM
9kFever's Avatar
Haha yea my old vortech s2k was BB. You take black for granted when it comes to testpipes. Silver shows it after a couple hundred miles.
Old Aug 3, 2008 | 02:18 PM
Series10's Avatar
Great Scott those are wicked numbers!
Old Aug 3, 2008 | 02:19 PM
9kFever's Avatar
I was excited. Hey did you have your HFC when you got tuned? What have you changed since the tune?
Old Aug 3, 2008 | 02:25 PM
Series10's Avatar
from the tune, I threw my stock wheels back on and washed with a different brand of soap.
