Vortech V2 supercharger peak power
How much power (HP) I can make from a Vortech V2 supercharger with 525 cc injectors/smaller pulley/Haltech PPP standalone
everything else is stock (stock exhaust/stock header..etc...)
test pipe installed only.
thank you guys,
thank you guys,
hold on I'm a little confused here?
so your saying 80 to 100 additional hp ?
that's it ?!!!!
why did I think a lot more, like 150 easy
is it the 60mm stock exhaust that's stopping me that much?
that's it ?!!!!
actually I have fuel pump that is providing enough pressure.
injectors ? bigger than 50lb/hr that I currently have?!!
and if this is stopping me? how much potential do I still have if I put
bigger injectors and say 70 or 76mm exhaust?!
Former Sponsor
Exhaust is not stopping you from making more power. That is misinformation. Maybe 10hp or so but not needed really.
Buy some higher quality 1000cc injectors. With a clutch and 4" or smaller pulley you should be near 400whp.
I made 406whp with the 60mm dual HKS exhaust on 12 psi(4") aem ems. F20 engine.
I have S1 HDSS ACT Clutch...
mmm ok I'll look for getting bigger injectors.
I don't remember the size of the pulley I have, I'll check and get back to you.
I appreciate your help
Former Sponsor
I'd definitely get some 1000cc injector dynamic injectors.
The vortech kit can make some nice power! I'd go for around 12 psi with the kit. Can even go for 14 psi and should be good as long as yo have a good tuner.
