VTEC Crossover
Old Jun 6, 2016 | 01:32 PM
amdaman's Avatar
Default VTEC Crossover
Hi - I know this has been asked many times and I've searched a lot but still need a bit of advice.
When my tuner set the VTEC he said something about a torque crossover on the chart and then set it @ 5700.
My setup is currently a Novi1000 @ 14psi but I'm just about to put a 1200 on at 16PSI+ .. should this lower the current crossover based on the method he did previously? At the moment when it goes into VTEC it just goes crazy at that RPM so I'm wondering if we lower it then it may be a bit more linear.
What should he be setting this to with my new setup as I feel 5700 is a tad high and it sometimes breaks traction in 3rd when it switches over.
Thoughts?
Old Jun 6, 2016 | 02:16 PM
JUSTINTHECOASTIE's Avatar
List your modifications please
Old Jun 6, 2016 | 02:34 PM
amdaman's Avatar
Novi 1200 16PSI+ / 98RON Fuel(New Zealand)
ID1000 + Walbro 255
Test pipe
AEM 1052u
Let me know if you need any other info
Cheers
Old Jun 6, 2016 | 04:17 PM
Chuck S's Avatar
Since the torque and horsepower curves of every engine ever made always cross at 5252 rpm (assuming the engine can rev beyond this point) I'm wondering what this is all about.
Torque is a scientific measurement. Horsepower is an arbitrary, made-up formula.
-- Chuck
Old Jun 6, 2016 | 04:46 PM
amdaman's Avatar
I'm honestly not sure how he got that crossover at 5700RPM I'll have to ask him and just relay what he says - I just haven't got the level of understanding. It just seems high to me. I've attached how it behaves at that crossover;
Old Jun 6, 2016 | 05:43 PM
liquid_helix136's Avatar
Lol so the correct way to determine a proper vtec is to set it to engage VERY low, (like 3k rpms) and do a dyno pull. Then set it VERY high (like 7k rpms) and do a pull. Then you take both of those graphs and look at where the torque curves meet.
Note my excellent visual aid
The blue line is what the torque curve would look like only running on the low cam profile (no vtec)
The red line is what the torque curve would look like only running on the high cam profile (always vtec)
Your goal is to replicate these graphs for your car, note where these two points intersect, and set that as your vtec engagement point, that way you maximize your low end torque on the low cam profiles as well as maximize power on the vtec cam profiles.
Since you have a test pipe, it should be around 3500-4200 rpms would be my guess.
Old Jun 6, 2016 | 06:14 PM
amdaman's Avatar
haha thanks for that - maybe that's what he did, not sure how that would bring 5700 rpm though. I'll talk to him when I take it in.
Cheers.
Old Jun 6, 2016 | 09:43 PM
My guess is he didn't add any timing to compensate for vtec, which commands another 5-6 degrees
Old Jun 7, 2016 | 02:59 AM
Chuck S's Avatar
Thanks for the diagrams. Where the two torque curves cross based on different cams. Suddenly makes sense!
Crossing looks remarkably like the 3600rpm VTEC set point my Gernby FlashPro tune is set for.
-- Chuck
Old Jun 7, 2016 | 03:09 AM
baZurk's Avatar
Taking MS paint skills to the LIMIT
