Walbro question
Old Apr 27, 2010 | 10:16 PM
NFRs2000NYC's Avatar
Use the OEM sock. If you use the Walbro, you will have problems with your gas gauge like I do. It only drops to 1/4 tank, then stops, so you will never know how much gas you actually have below that 1/4 mark.
Old Apr 28, 2010 | 11:21 AM
08s2000CRbackinblack's Avatar
Originally Posted by 91crxdx,Apr 27 2010, 04:28 AM
I did a lot of research before I installed my Walbro 255 and it seemed like everyone agreed it was better to use the OEM filter sock. I just used my old one. The Walbro was much longer and seemed like it would cause issues with the fuel gauge levels because it hit the arm.
does anyone have any advice on how to get the clip off that holds the fuel filter to the bottom of the pump? just pry with a screwdriver? i dont want to break it. thanks
Old Apr 28, 2010 | 11:41 AM
s2000Junky's Avatar
Exactly. I figured this out the hard way.
re use OEM everything! Just swap the pumps
Old Apr 28, 2010 | 12:53 PM
Spoolin's Avatar
If you're referring to the itty bitty round clip thingy that goes over that little post, just use a small screwdriver and slowly walk around it while lightly prying it up as you go. Then, just use a small, like 4 or 5mm long socket to push the new or old clip onto the new pump once you have the filter on. The new filter should have one of these itty bitty clips with it but if it doesnt, just reuse the old one from the stock pump filter.
Old Apr 28, 2010 | 10:38 PM
slackfaster's Avatar
lots of good info here -- thanks everyone
Old Apr 29, 2010 | 11:32 AM
i started to rip my trunk apart to see what ill be looking at this weekend when i do my instal. i noticed a unused plug cominh from the same wire harness as trhe fuel pump power and was mounted and just sitting there right where the pump is mounted into the tank. dpoes anybody know what this extra wire harness clip is for? cd changer?
Old Apr 29, 2010 | 12:13 PM
Spoolin's Avatar
Thats probably for the OEM twin pumps you could have ordered. LOL jk
I'm sure its for the CD changer or something but I'm not too sure.
Old Apr 30, 2010 | 01:44 AM
Saggio's Avatar
Another one here that says, OEM filter.
GreenmanS2000
Mar 24, 2012 12:18 PM
Forcedbird
Jun 17, 2011 05:53 PM
dr.s2k
Feb 2, 2011 07:56 AM
Bully9
Dec 8, 2006 08:01 AM
