Wastegate question?
Im in the middle of doing a turbo build and dont know what bar of pressure i should get for the wastegate wont be running nothing over 20psi and its a twin scroll manifold so I Need 2 wastegates
Wastegates come with different springs that you can combine to reach you desired boost level. If you want to keep target psi the same for every gear then the closer the spring pressure to the target boost pressure the better
So say im going to run 20psi your saying i should get 2 wastegates that are 10psi or 2 that are 20
It'd be silly to go through the trouble/expense of a twin-scroll setup and then use spring pressure or a manual boost controller to control your boost levels.
