Wastegate question?
Old Feb 19, 2014 | 11:50 AM
Capitan29's Avatar
Default Wastegate question?
Im in the middle of doing a turbo build and dont know what bar of pressure i should get for the wastegate wont be running nothing over 20psi and its a twin scroll manifold so I Need 2 wastegates
Old Feb 19, 2014 | 11:53 AM
baZurk's Avatar
Wastegates come with different springs that you can combine to reach you desired boost level. If you want to keep target psi the same for every gear then the closer the spring pressure to the target boost pressure the better
Old Feb 19, 2014 | 12:18 PM
Capitan29's Avatar
So say im going to run 20psi your saying i should get 2 wastegates that are 10psi or 2 that are 20
Old Feb 19, 2014 | 12:20 PM
baZurk's Avatar
2 gates with 20psi springs in each one
Old Feb 19, 2014 | 12:21 PM
baZurk's Avatar
I would run less spring though and use a wastegate solenoid to control boost pressure past your spring pressure to ensure constant boost levels
Old Feb 19, 2014 | 12:49 PM
Capitan29's Avatar
I have aem truboost gauge and it came with the boost controller solenoid
Old Feb 19, 2014 | 12:50 PM
blasphemy101's Avatar
+1
It'd be silly to go through the trouble/expense of a twin-scroll setup and then use spring pressure or a manual boost controller to control your boost levels.
Old Feb 19, 2014 | 01:29 PM
Capitan29's Avatar
So what spring wastegates should I get. I have a boost solenoid
Old Feb 22, 2014 | 06:57 AM
RacerXI's Avatar
Pick the lowest spring pressure you ever plan on running. That's around 7 - 10psi for most people.
Old Feb 22, 2014 | 01:53 PM
camuman's Avatar
I agree with Mr T
