wastegate and wastegate spring size
Old Mar 28, 2009 | 07:24 PM
ChefJ's Avatar
Default wastegate and wastegate spring size
I currently have the IP kit and a turbosmart 38mm wastegate. Its the older turbosmart. I am curious as to if they have springs still available for this wastegate, preferably a 14psi. If not what size wastegate can I go up to with the IP log mani. I just don't want to have to worry about the boost controller and spikes. Thanks.
Old Mar 28, 2009 | 09:24 PM
Spoolin's Avatar
From what i have learned so far but its not confirmed just yet, you will need a spring rate that is at least half the amount of boost youre running or you could run into boost controller problems and boost not holding all the way to redline.
Old Mar 29, 2009 | 07:08 AM
rob!'s Avatar
www.extremepsi.com sells them and they have a chart with what color spring = what psi/bar you want.
Old Mar 29, 2009 | 07:09 AM
ChefJ's Avatar
Are there any sites that still sell the springs for the older streetgate. The new model ultra-gate seems to be everywhere. I just don't want to upgrade to a new unit just to get a stronger spring.
Old Mar 29, 2009 | 07:35 AM
rob!'s Avatar
you sure the springs are the different, im pretty certain they are the same. I know tial springs work on the older style gate
Old Mar 29, 2009 | 07:45 AM
nextinstant39's Avatar
On the IP manifold its just a 38mm gate flange. So a tial will also work, or any 38mm gate with the same style flange.
As far as the spring size, as said before, half the boost, mabye a bit more will be good. Only bad part is you can only run that setting as a minimum boost obviously. Id go with a 14ish psi spring.
Old Mar 29, 2009 | 09:19 AM
ChefJ's Avatar
I have an 8psi spring and am running around 22psi at 64% on my BC. Its fairly consistent as far as psi is concerned, but when I do decide to turn it up to 26-28psi I want a bigger spring. I don't want to port the hole on the mani larger for a larger gate but also don't want to pay 300 ish bucks for a new gate when I can spend 25 on a spring.
liquidgsr
Nov 15, 2012 04:10 AM
Kitesurfer s2000
Oct 7, 2012 01:58 PM
JuicedS2K
Jun 21, 2010 07:31 PM
roi
Jan 6, 2009 07:48 AM
jbotstein1
Mar 27, 2007 06:45 AM
