WB O2 Sensor without pulling the header?
Old Oct 27, 2006 | 10:35 AM
WLAURENT's Avatar
Default WB O2 Sensor without pulling the header?
Anyone found a way to add a WB sensor bung without removing the header?
Anyway to mount it on the nose end of the cat?
Old Oct 27, 2006 | 10:54 AM
pushin9's Avatar
i put mine in my test pipe.
Old Oct 27, 2006 | 03:57 PM
revhi's Avatar
I did to even though they say it should be closer. Ive compared mine with the dyno shops and it seems dead on.
Old Oct 28, 2006 | 05:25 AM
mikey k's Avatar
Why not use a WB in the OEM position and get a WB that outputs Narrow band to the ECU
Old Oct 28, 2006 | 06:25 AM
Soul Coughing's Avatar
plx-250 does narrowband as well. I am goin to remove the narrowband and use it to run the closed loop. from what i hear, it actually improves driveblilty... just make sure to use a ground as near to where the sensor does so it sees the same voltage. Also you would need to either keep the plug dangling or put in a resistor to let the ecu know that it has been heated... good luck!
Old Oct 28, 2006 | 02:37 PM
EK9MAX's Avatar
I had mine in the test pipe. Then took teh test pipe off.
So I had it reinstalled in the header rigth before the flange. This was all done at the shop without removing anything.
Old Oct 28, 2006 | 04:25 PM
WLAURENT's Avatar
I went ahead and put it in the nose of the cat-con since I was doing it myself and the car was only on jack stands and I did not want to be welding under the car with only a foot or so of space.
No clearance issues and I think the finished product was clean and neat:
Not boosted yet, just getting ready for it. Guess my MY02 runs a bit on the rich side for being NA still.
IDLE - 14.5
CRUISE @ 55 MPH - 14.5 to 15.2
WOT 3nd Gear 2000-6500 RPM - 11.2
WOT 3nd Gear 6500-9000 RPM - 11.8
Old Oct 29, 2006 | 03:39 AM
mikey k's Avatar
That is very tidy!
I thought about trying that
I'm convinced - That's how I'm going to do mine!
Old Oct 29, 2006 | 04:37 AM
Bibbs's Avatar
I was going to to this, but then I'll need to swap the de-cat for the cat when it comes to the yearly car tests. I didn't want to have to keep swapping other sensors.
Swapped out the one in the end of the manifold and then using the narrowband output to the ECU.
Old Oct 29, 2006 | 04:48 AM
mikey k's Avatar
That's what I was planning but I'm not decatting and like the idea of leaving the ECU system as untouched as possible with this SC install
lopez14
Nov 7, 2013 11:51 AM
fallen612
Apr 21, 2011 07:13 PM
S2k_girl
Sep 15, 2007 10:50 AM
jdmdohcpower
May 23, 2005 05:00 PM
Dolemike
Dec 15, 2004 01:33 PM
