welding cracked manifold while still on the motor
Old Jun 5, 2010 | 07:33 PM
Deception's Avatar
Default welding cracked manifold while still on the motor
Found the source of my bad boost leak.. Rev hard manifold has a crack on the top, running from wastegate flange towards the motor.
Is it safe to weld the crack while manifold is still on the motor? What should I do? Pull the ECU & battery first?
My friend can weld it for me tomorrow. If it doesnt hold, or I need to remove it Im just gonna get another one.
thanks
Old Jun 5, 2010 | 07:39 PM
rob!'s Avatar
yeah you can weld it on the car no problem. disconnect the ecu and battery if you want to be safe.
Old Jun 5, 2010 | 07:42 PM
Deception's Avatar
thanks Rob
I hope we can get to all areas of the crack, even if it lasts a month or 2 it will give me time to get my shit together.
Old Jun 5, 2010 | 08:07 PM
MaseEng Nick's Avatar
rev hard is a cast manifold right?
i would remove it... cast needs to be welded using steps...
grind out the crack, preheat the piece, weld the crack, post heat and then wrap the piece with a fire blanket to slowly let it cool down.
Old Jun 5, 2010 | 08:20 PM
RedLineS2k10's Avatar
This is the more proper way of doing this, if you want a proper job.I had the same problem on a DC stainless steel turbo manifold, the problem is, once its fixed theres no gurantee its going to hold. Mine had been welded so many times i just got a new log manifold. I would fix it for now to save $$, but i would replace it in the future. Hope this helps
Old Jun 5, 2010 | 08:22 PM
Deception's Avatar
yeah im just doing this as a temp fix... the wallet is getting hit hard this month
Old Jun 5, 2010 | 08:24 PM
dsddcd's Avatar
Wow, you are good. There are not many people that know how to properly weld cast. If done properly it should last for a very long time.
Old Jun 5, 2010 | 08:25 PM
temp fixes turn into a welders PITA!!!
Old Jun 5, 2010 | 08:28 PM
Old Jun 6, 2010 | 03:42 PM
ChefJ's Avatar
Best part about cast is the fact that you can go pretty dep with the weld. Turn the juice up and let it penetrate.
