welding cracked manifold while still on the motor
Old Jun 6, 2010 | 04:02 PM
Revenge's Avatar
I know of another member who had this manifold and had it repaired.
Old Jun 8, 2010 | 09:32 AM
Deception's Avatar
The weld helped a bit, but there is still a crack that is beyond our reach with the manifold still on the car. The crack also went through the WG flange on one side. Im just going to get a new manifold & be done with it.
This maybe a silly question, but what material is the compressor cover on a precision turbo.. alum or steel? I want to weld on an 90 deg angle so i dont have to use the 90 silicone coupler anymore.
http://vibrantperformance.com/catalog/prod...roducts_id=1280
Old Jun 8, 2010 | 10:23 AM
siadam's Avatar
Alum.
Old Jun 10, 2010 | 12:51 PM
Deception's Avatar
Any theories on how my manifold cracked? Whats the common denominator in these cases?
I didnt do the work myself last time, but Im sure as hell doing it myself this time.
Old Jun 10, 2010 | 12:57 PM
dsddcd's Avatar
Heat cycling, vibration and stress all lead to the fatigue and eventual failure.
That is what happens when you get a poor casting or improperly designed peice.
I was measuring temperatures from 800F at light cruising to 1700F+ during a pull on the highway on my IP manifold.
Old Jun 10, 2010 | 01:03 PM
Deception's Avatar
I see, I don't know how many miles my old manifold had on it since I got the kit used from what turned out to be a shady seller.
Hopefully this brand new one will hold up until I can get a nice PFab tubular or something.
Old Jun 11, 2010 | 06:18 AM
m R g S r's Avatar
for your power level, just get the IP cast manifold.
Old Jun 11, 2010 | 07:36 AM
Deception's Avatar
I got another revhard, brand new
Pretty sure I would have to notch the frame rail to fit my turbo with the IP mani, and modify my downpipe
Old Jun 11, 2010 | 11:28 AM
Revenge's Avatar
You probably would have to notch it but its not really a big deal. Also the inline manifold is a better design, it has small runners.
skool u
May 19, 2016 04:16 AM
zaff
Dec 1, 2012 09:51 AM
PistolPete76
Apr 7, 2010 10:43 AM
Envied
Oct 2, 2009 04:52 PM
jzz30
May 20, 2007 12:05 PM
