What could have gone wrong?
Old Jan 29, 2010 | 02:55 PM
sleepinggreys2k's Avatar
Default What could have gone wrong?
Breif summary of the story:
I hit the dyno and my engine was taking some prestone...soon too discover the head-gasket blew on the head side
I finnaly get around too fixing it all up today(Everything done too spec/head was sent out for pressure testing and machined)...But when puting the fluids in (too be more precise prestone) well it leaks inbetween the block and head on the passanger side close too cylinder number 4...
What could have gone wrong?...Theres new oil in + filter + spark plugs
Useless but heres a pic of the set-up...wasnt complete but you get the idea
Old Jan 29, 2010 | 03:13 PM
fastD's Avatar
It leaks when you add the coolent? Without any pressure?
Old Jan 29, 2010 | 03:20 PM
Exactly , as im filling it up it just leaks out...Either way ill just get the cams off sunday and try re-torqing it all back see if it changes anything maybe i missed something along the way
other then that i have no idea what too do...
Old Jan 29, 2010 | 08:00 PM
scheister's Avatar
Did you check the block too?
Old Jan 29, 2010 | 08:28 PM
Nope didnt check the block since the head-gasket blew from the head side
Old Jan 29, 2010 | 09:55 PM
S2Kmonkee's Avatar
what's that on your intake?
Old Jan 30, 2010 | 06:03 AM
im not sure what you mean but...AEM 3.5 bar map sensor and Tial 50mm bov
Old Jan 30, 2010 | 09:42 AM
Just took the cams..and check the torque on the head studs...and re-torqued them and it still leaks
Old Jan 30, 2010 | 10:38 AM
ap1tuner's Avatar
Dude aLl I can think is... Damn that sucks! I hope you can figure it out soon.
Old Jan 30, 2010 | 06:48 PM
Spoolin's Avatar
Oh man! Sorry to hear this. You may have to pull the head and make sure something didnt get lodged between the head and block when you torqued it back down. Sounds like something isnt letting the head fit flat down on the block correctly. Are you using the IP 3mm HG? You can get another OEM HG, pull the rivets and split it. Then pull the rivets off the IP 3mm gasket and remove the old gasket and put the new OEM gasket around the IP 3mm spacer without riveting it back on. Make sure to pull the thin spacer out of the OEM gasket before doing this though. You are basically just replacing that thin OEM spacer with the IP 3mm spacer. This is how IP makes their gasket except they rivet it back together for shipping. You dont have to rivet it though.
SlosIIk
Feb 26, 2013 02:53 PM
bobonacus
Jun 21, 2012 02:14 AM
AP1FTW
Aug 27, 2009 05:18 AM
gearshifter
Socal Swap Meet
Apr 13, 2009 09:48 PM
g352s2k
Jun 30, 2007 01:29 AM
