what power on are you making on 3mm headgasket
Old Sep 30, 2009 | 10:03 AM
ssjmikeg's Avatar
Default what power on are you making on 3mm headgasket
hey got my car tuned. and made 404whp on heartbreaker dyno dyno pack 3000.
was looking to see what everyone else made on there setups with 3mm headgasket.
plz put what turbo, mani, and exhuast you were using and PSI include the what type of fuel. any other info is good to thanx
my set up is gt3076r with 82 hot side.
IP log
vibrant 3in turbo back.
3mm IP headgasket, arp headstuds (studs dont matter)
and roughly 19-20 psi.
Old Sep 30, 2009 | 10:13 AM
spectacle's Avatar
<--- runs away from this thread.
Old Sep 30, 2009 | 10:14 AM
killabee's Avatar
421hp/298tq
60-1 garrett turbo 82 hot side
AFI mani
3" Turbo back
3mm Ip headgasket,arp headstuds
12psi
Old Sep 30, 2009 | 10:28 AM
camuman's Avatar
did u run away becuase
A. 3mm HG is touchy subject on this board
B. which is why i am running away, becuase he called a dynapack dyno a heartbreaker dyno ROFL.
the only heartbreaker dyno is a dyno dynamics, and only when left in uncorrected mode.
dynapack removes the wheels, there is ZERO way it can break hearts with the removal/decrease of rotational mass and tire resistence.
i now shut my mouth.
Old Sep 30, 2009 | 10:36 AM
neeman77's Avatar
616 hp/494 ft lbs dyno dynamics 29 psi on c16
Pfab ELTM twin scroll manifold
Divided GT35R 1.06 A/R
3" turbo back
OEM Headbolts
Old Sep 30, 2009 | 10:49 AM
ssjmikeg's Avatar
I say heartbreaker because mnay people have reported this dyno to be a low reading dyno of about 30whp
Old Sep 30, 2009 | 01:35 PM
neeman77's Avatar
Its probably the highest reading.
Old Sep 30, 2009 | 04:19 PM
s2mmkay's Avatar
um.. hes running away because theres a thread with the same title right below yours... do you even search before you post up a new thread?
Old Sep 30, 2009 | 05:09 PM
neeman77's Avatar
This one? What numbers are you making on *stock* headgasket?
Old Oct 1, 2009 | 03:48 AM
ssjmikeg's Avatar
this thread is for 3mm headgasket not stock head gasket you read befor you post.
