what size electric cutout?
Old Dec 31, 2012 | 03:19 PM
Sarek's Avatar
Originally Posted by andrewv
Instead of finding a good dual exhaust, I am thinking of just putting my stock ap2 exhaust on in conjuction with having an electric cutout. I assume these get welded into the downpipe or test pipe? What size would I get, a 2.5 or 3"? That way I can have it quiet if I am just cruising around and if I want I can have the benefits of running open dp practically.
That's a great idea. Very sleeper.
SP boost cutout is one of my favorite mods post turbo. Under 9-10 lbs, it's sounds like stock.
Old Jan 2, 2013 | 06:43 AM
illestrolla's Avatar
Yezzzir, I am going to be picking one of these up myself as well!
Old Jan 2, 2013 | 07:15 AM
gnehc1's Avatar
Not to thread jack, but where do u hook up the nipple for the vacuum hose from the actuator to?
Old Jan 2, 2013 | 07:27 AM
Any manifold pressure source.
Old Jan 2, 2013 | 09:25 AM
Sarek's Avatar
FYI, If you look at my video you can see that it closes pretty fast. I can hear it close shut between each shift, a little too fast for my complete liking. Some of the Supra guys plumbed a tee to a bleeder valve to slow it down some. Not a big deal but next time I get under the car, I'm probably going to add that.
Old Jan 2, 2013 | 09:52 AM
dsddcd's Avatar
You can add a restrictor and try that first if you wanted, it will slow the reponce and you can buy it at most autoparts stores. I had to use this with pressure transducers in the past and was quite happy.
As for what cat back to use, I did not want anything but the OEM which is why I put in the valve in the first place. That and the exterior was 100% OEM so I got to have some fun with a bunch of people. I loved the look on their face when the valve opened!
It tooks a better fabricator than I but this proved to be my favorite location.
Sleeper!
Old Jan 2, 2013 | 10:25 AM
Sarek's Avatar
That looks great Scott!
Old Jan 2, 2013 | 10:29 AM
Yea absolutely a pristine install there!
I want one bad!!!! I can't bring myself to part with my T1R duals, but I just can't make any real power with them, so this will be the perfect solution.
Old Jan 2, 2013 | 03:15 PM
Killer_B's Avatar
I had the generic brand, 3" e-cutout from Jegs and it broke about 5 times.
The screws kept backing out.
Lmk, where I can get an inexpensive boost actuated cutout...
Old Jan 2, 2013 | 05:00 PM
watch0bak's Avatar
https://www.s2ki.com/s2000/topic/996...ipe-group-buy/
Check out this one! I have the first one they made and have no complaints about it!
