What are you guys doing to stop this?
ARP 3/8 x 1" bolts. Wired, lockwasher, and baptized.
Still breaking.
The broken bolts came out by hand but damn do I need to fab a brace for this Pfab top mount? I dont know what hardware is going to be stronger than the ARP?
Still breaking.
Several of the bolts look to be grade 5 bolts (indicated by the markings in the heads) it is hard to tell from my phone but I would check that out.
Secondly the material selection is key also. I would recommend using a standard mild steel. You want the material to be ductile and have a thermal expansion to match the manifold flanges. If you can get close ups of the surfaces the sheared you may be able to get a better idea of why it failed by doing a bit of searching online.
Originally Posted by 05TurboS2k' timestamp='1334638121' post='21614562
Ceramic coat INSIDE and OUT. Problems will be gone.
I can run regular home depot hardware and have no problems now.
ceramic coating works wonders. My top mount pfab manifold is ceramic coated, as well as the turbo hot side. Never had a stud issue.
just sayin
