What are you guys doing to stop this?
Old Apr 16, 2012 | 08:27 PM
o'malley_808's Avatar
Default What are you guys doing to stop this?
ARP 3/8 x 1" bolts. Wired, lockwasher, and baptized.
Still breaking.
The broken bolts came out by hand but damn do I need to fab a brace for this Pfab top mount? I dont know what hardware is going to be stronger than the ARP?
Old Apr 16, 2012 | 08:38 PM
redboost10's Avatar
I have never had good luck with threaded flanges. I drill the threads out and use grade 8 bolts and nuts with a washer and lock washer on top and bottom.
Old Apr 16, 2012 | 08:48 PM
05TurboS2k's Avatar
Ceramic coat INSIDE and OUT. Problems will be gone.
I can run regular home depot hardware and have no problems now.
Old Apr 17, 2012 | 01:12 AM
Leviisbigred's Avatar
they have grade 8 bolts at home depot just sayin
Old Apr 17, 2012 | 04:51 AM
Corey Maurer's Avatar
Full Race sells a stud and nut kit I will be running, supposed to work well, but it's pricey so well see if it's worthwhile
Old Apr 17, 2012 | 05:10 AM
passmans2kny's Avatar
i'm running the full race nuts and studs, no issues so far
Old Apr 17, 2012 | 05:15 AM
DFWs2k's Avatar
Running lowes hardware, no issues for 30k miles
Sent using free Tapatalk - Android FTW
Old Apr 17, 2012 | 05:34 AM
dsddcd's Avatar
Several of the bolts look to be grade 5 bolts (indicated by the markings in the heads) it is hard to tell from my phone but I would check that out.
Secondly the material selection is key also. I would recommend using a standard mild steel. You want the material to be ductile and have a thermal expansion to match the manifold flanges. If you can get close ups of the surfaces the sheared you may be able to get a better idea of why it failed by doing a bit of searching online.
Old Apr 18, 2012 | 12:06 PM
HiVolume's Avatar
ceramic coating works wonders. My top mount pfab manifold is ceramic coated, as well as the turbo hot side. Never had a stud issue.
Old Apr 18, 2012 | 01:35 PM
The hot side of the turbo is ceramic coated with turbo blanket. Still no luck
