whats next
Old Dec 19, 2010 | 05:08 AM
s2kbuild's Avatar
Default whats next
I have an 05 s2000 pushing 400hp on boost and I'm wondering what is the next step I've been told that the stock diffs might granade. I've also been told it is a gamble because some do and some don't just depends on how lucky you are. My luck is not something I want to test with my baby. So is this true? Second what else should I get as insurance and that will help me grow later down the road. I'm sorry if my questions are dumb but I'm new to the honda family and I use to drive a turbo II rx7 while back but was even dumber and did not ask questions to keep it maintained. Any help would be greatly appreciated.
Old Dec 19, 2010 | 05:47 AM
JoeyBalls's Avatar
A few issues I ran into, you might too
HeadGasket (dunno if you have a 3mm)
Manifold/turbo bolts coming loose
Blowing apart AXLE parts due to increased power
As far as Insurance, I would get an EGT Gauge (I dont care where you place it, you will know if something is going wrong if it spikes hire than usual)
AFR gauge, Water Temp Gauge, Oil Pressure gauge, Boost gauge
Have a good tune with Boost cut etc,,,,,,,,,,,,,,
Old Dec 19, 2010 | 05:53 AM
s2kbuild's Avatar
Which axle parts specificly?
Old Dec 19, 2010 | 06:14 AM
s2kdan05ems's Avatar
get diff collars for smooth power transfer to the diff. 0 play
Old Dec 19, 2010 | 06:31 AM
DFWs2k's Avatar
Get spare axles, diff and maybe tranny if you don't want any downtime. Usually if tranny pops, you only lose a gear, so maybe don't worry about that, and you are probably safe tranny-wise (if you don't powershift, etc) since you aren't making very much power.
If you don't want to break diff or axles, don't launch or learn how to launch correctly, and you'll probably only have to worry about increased wear and tear due to increased power, and you'll know.when parts are getting.worn out.
Old Dec 19, 2010 | 06:52 AM
400 is pretty headache free , thats why i did it
Old Dec 19, 2010 | 02:12 PM
JoeyBalls's Avatar
300HP could be full of headaches, power isnt the only indicator if headaches
Old Dec 19, 2010 | 03:03 PM
StocS2k's Avatar
Buy some good Lock nuts or use double (2) hex Nuts on the manifold to turbo
Wideband Gauge
Boost Gauge
Oil Pressure Gauge
Stay with oem HEAD GASKET no MATTER WHAT!!!!!!!!
Good Tune!
What boost you running?
Old Dec 19, 2010 | 05:15 PM
Euroflavor's Avatar
O RLY?
Old Dec 19, 2010 | 05:34 PM
StocS2k's Avatar
Originally Posted by Euroflavor,Dec 19 2010, 06:15 PM
O RLY?
Look at all the Fails people are experiencing with the 3mm ILP no offense but most go right back to oem. Better off not opening the the engine.
Show me some people that have 10 to 20k on there 3mm gasket or any other than oem.
