White smoke everywhere....
Old Nov 19, 2010 | 01:21 PM
Fallen's Avatar
Default White smoke everywhere....
Hey guys so recently after the turbo install im getting enormous amount of white smoke.
Its not bluish or black it's white..
When i start the car there is no smoke and after couple of minutes of driving smoke comes. When im driving i get huge smoke clouds behind me from the exhaust ,but when i idle my vented hood smokes too..
Any ideas what could be the reason??
Old Nov 19, 2010 | 01:22 PM
broke 20's Avatar
How old is the turbo? Possible seals have gone bad?
Old Nov 19, 2010 | 01:27 PM
HMFIC's Avatar
need some more info... What turbo kit?
sounds like either the turbo seals OR the drain line isn't draining well enough.
Old Nov 19, 2010 | 01:35 PM
Fallen's Avatar
Well its the turbonetics turbo.. Its new turbo so i dont know about the seals already going bad..
But maybe my drain line like HMFIC said doesnt drain well..
Old Nov 19, 2010 | 01:42 PM
Shftat9k's Avatar
^^Then the smoke would not be white. White equals coolant being burned, bluish would be oil, and black for rich mixture.
Is it a water cooled turbo? Did you do a headgasket?
Old Nov 19, 2010 | 01:50 PM
broke 20's Avatar
I always get mixed up between blue (oil) and white (water) Maybe try a compression test and go from there....
Old Nov 19, 2010 | 03:23 PM
Deception's Avatar
I agree its hard to tell a lot of the time, when my car was burning 1qt every 15 mins the smoke looked pretty white to me
Old Nov 19, 2010 | 03:55 PM
broke 20's Avatar
Whoa thats a lot of oil!!
Old Nov 19, 2010 | 04:23 PM
08s2000CRbackinblack's Avatar
yes i can attest for white oil smoke too, distinct smell of oil
Old Nov 19, 2010 | 05:41 PM
Dan1987's Avatar
another possibility is over-filled oil, causing oil to flow through the PCV valve into the inlet manifold.
On the off-chance, check your oil level.
