Why 12PSI on stock comp with Meth?
Old Oct 11, 2008 | 04:06 PM
stena's Avatar
I was,like you worring all day before i got my parts to up the boost..
If i had the resources as you do in the states i wouldnt have tought twice to do it( Tuners,good grade fuels,race ect,)
but i decided to do it anyway,i bought myself a J&S safeguard in case the motor starts to detonate and i dont take my Foot of WOT..
I am running near 15psi and i am in situation where i have no Tuner that understands anything,no real Dyno Tuning done and no one to do the Work around what goes where and i still did it,and i am running 10000miles no problems..
so nothing to worry about if i was on your place.
I had Tuning Help from MASE since he has done many S2000 with Stock CR and high boost.
430hp last time i went on the dyno.
Stefce
Old Oct 11, 2008 | 04:13 PM
JoeyBalls's Avatar
Jesus Christ, 15psi ON STOCK COMPRESSION that is impressive wow, I guess as they say, "its all in the tune" really holds true With METH and a good tune I should safely run 12PSI then
Old Oct 12, 2008 | 06:26 AM
SgtB's Avatar
All day.
Old Oct 12, 2008 | 06:47 AM
s2000442's Avatar
Why don't more people use W/M with SC or turbo at higher psi? Just seems like cheap insurance against detonation to me.
Old Oct 12, 2008 | 07:33 AM
PatS4P's Avatar
Banned
it is.
Old Oct 12, 2008 | 07:46 AM
Spec_Ops2087's Avatar
Why don't most people "do it right" the first time instead of cheaping out on parts (and eventually they fail)?
Old Oct 12, 2008 | 07:53 AM
JoeyBalls's Avatar
Hey now, I did it right the first time, the METH is "addional" for me, not a bandaid, I am getting it tuned in Nov
Old Oct 12, 2008 | 08:31 AM
s2000442's Avatar
You are right, cutting corners with FI is just asking for trouble. I think people have an unrealistic budget in mind. If it is not really required, then they will cut corners to save a buck. This usually ends up costing them more in the long run to fix a problem later down the road.
This should be a required add on for anyone who wants long term reliabilty and safety for their turbo.
I did not know much about W/M injection either Joey until I started reading the FI forums. Thanks for bringing it out in the open with your threads
Old Oct 12, 2008 | 08:40 AM
jwa4378's Avatar
Whoah there Joey! I think most people running 10+ psi have a stand-alone EMS... I know "stena" does... If you are running E-Ultimate (from the standard Greddy kit), I would be less trusting in its ability to crazy adjustments as consistently. Its still a piggy-back.
John
Old Oct 12, 2008 | 09:15 AM
JoeyBalls's Avatar
hmmmmmm interesting, I guess Ill discus with my tuner, He said I would just need the Greddy MAP and harness, but I wonder what problems I would see with the Ultimate.
Why would the E-Manage Ultimate be ok with 10PSI, but not trustworthy at 12PSI?
