Wideband 02 using AEM ems question
Old Aug 27, 2012 | 04:18 AM
s2kseven's Avatar
Default Wideband 02 using AEM ems question
I have a AEM ems 1052.
I deleted my two stock s2000 02 sensor and replaced it with 02 sensor wideband from Innovate.
I want to wire the Innovate wideband to my Honda stock harness. Anyone here can tell me what pin # at the honda ecu plug harness that I need
to cut, rewire or re-inserted?
Old Aug 27, 2012 | 05:43 AM
herecomesboost's Avatar
Pin C16
Old Aug 27, 2012 | 06:50 AM
s2kseven's Avatar
Originally Posted by herecomesboost
Pin C16
The wideband 02 sensor has 5 wires BLACK - GREY - LIGHT YELLOW - RED - WHITE (OH, by the way my wideband is not INNOVATE but AEM came with the ECU)
which color wire should go to PIN C16 of the Honda harness plug?
Just one wire required ?
Thank you very much!!
Old Aug 27, 2012 | 07:20 AM
Originally Posted by s2kseven
Originally Posted by herecomesboost' timestamp='1346074983' post='21967251
Pin C16
My apologies; I incorrectly assumed that you were using a gauge type UEGO (which typically have a 0-5v output wire; which would go to C16 (Lambda#1)).
Old Aug 27, 2012 | 07:21 AM
What is your sensors model number?
Old Aug 27, 2012 | 08:41 AM
s2kseven's Avatar
There are so many numbers in the AEM 02 sensor.
12575657
0258 007 206
LSU 4.2
Old Aug 27, 2012 | 10:23 AM
12575657
0258 007 206
LSU 4.2
Found your sensor (AEM # 30-2001)
http://www.oxygensensor.net/bosch_o2/17205.php
I don't think you're going to be able to splice that sensor into the stock wiring. I suggest buying a gauge or controller for your current sensor.
Old Aug 27, 2012 | 11:33 AM
s2kseven's Avatar
Thank you...how about this: http://img27.imageshack.us/img27/7057/aem02wiring.jpg
I want to buy an AEM air fuel ratio gauge. I can plug the 02 sensor & the extention wire directly to my AEM ecu port. What wires are needed for the gauge to work?
As I mentioned above the 02 sensor has 5 wires, the extention wire has 6 GREEN - WHITE - RED at the bottom of the plug is BLACK - BROWN - ORANGE.
The green has no connection to the 02 sensor.
Sorry for the questions, I bought this unit with no manual.
Old Aug 27, 2012 | 01:09 PM
Do you have a 1052 or 1052U?
Old Aug 27, 2012 | 04:55 PM
s2kseven's Avatar
Just 1052
JakexTrainer
Feb 6, 2019 04:11 AM
jb34304
Jun 5, 2010 04:21 PM
s2kadrenalin
Oct 3, 2008 07:20 AM
ideugene
Apr 17, 2006 07:40 PM
AusS2000
Feb 19, 2005 07:48 PM
