wideband broken?
Old May 6, 2011 | 08:39 AM
erikvanden's Avatar
Default wideband broken?
My wideband appears to be on the fritz. Sometimes it works like normal but othertimes it seems like it gets suck around 14.5. Even flooring it and getting the revs up wont richen it up and letting off the gas won't lean it at all. Other times it is all over the place. It is a glowshift wideband gauge so I know it wasn't of the highest quality, however the sensor it uses is a bosch LSU 4.9. I assume the gauge it's self just reads the output from the sensor and their for the gauge its self shouldn't be important as it is just reading what the sensor tells it to.
So is their something wrong with my sensor? The wire for it is a little pinched since the sensor is so close to the underbody of the car but it appeared to be fine when I put it in and if it did short I would assume it wouldn't read anything not mid 14s. Plus last time I checked the sensor wire it looked fine. Anyone have any idea what is going on? Their defiantly seems like their is something wrong as the afrs don't seem to match my throttle response most of the time and if the afrs shown are true my engine should be blown.
Old May 6, 2011 | 08:44 AM
sujo's Avatar
I had similar happen when the wiring hit my transmission and sat on it...and melted
Old May 6, 2011 | 09:28 AM
redboost10's Avatar
When sensors go bad they will start reading around 14.7 all the time. So if the wiring is fine then more thanlikely the sensor is going bad.
Old May 6, 2011 | 09:32 AM
razzele's Avatar
not true-
my aem sensor diconnected from the gauge it read 14.7
plugged it back it and worked normally
Old May 6, 2011 | 09:34 AM
redboost10's Avatar
Hence why I said if the wiring is fine.
Old May 6, 2011 | 10:19 AM
EliteTuning's Avatar
Thread OP
Unplug and replug your wideband then test. If no change, check wiring. Re-test. If all wires good, your wide-band should have come with a test checklist. If you don't have the manual, I'm sure you can find one online or contact the company for technical support.
Old May 6, 2011 | 11:16 AM
erikvanden's Avatar
wow, you couldn't have called that better. I had known that they normally read in the 14s when going bad so I assumed that was the problem (i didn't want to say anything because I didn't want to be bias), either that or the crappy glowshift gauge. I just jacked the car up to insure that the wire wasn't the problem. There was defiantly damage to the wire where it was touching the body. I brought the pipe to a shop and had them weld a new bung so it would be out of the way. I then was able to cut the main wire open and electric tape the wires. I think it was grounding out on the car. Upon reinstalling it appeared to fix the problem. Well fixed the gauge... now my AFRs are back to all over the place.
thanks for the help everyone.
Old May 7, 2011 | 05:11 PM
sohc_mshue's Avatar
Yea definitely sounded like a disconnected wire. Typically when the sensor starts to go bad you will see lean spikes.
cmn
Feb 1, 2014 12:16 PM
icemans2k02
Jun 27, 2006 08:09 PM
payyourtoll
Jun 20, 2003 04:44 AM
S2K
Sep 13, 2002 12:21 PM
