Wiring diagram with engine sensors?
Old Jan 28, 2014 | 01:18 PM
cmn's Avatar
cmn
Default Wiring diagram with engine sensors?
Does anyone have a wiring diagram with the engine sensors, or more specifically engine coolant temperature (ECT) sensor? Looking to connect a PLX water temp gauge, and would prefer to use the oem sensor because of the location, and also the simplicity of not needing another sensor.
Trying to find out if I can connect the gauge somewhere inside the car, or if I need to pull another wire directly from the sensor through the firewall.
Appreciate any help!
Old Jan 30, 2014 | 09:57 AM
2big4aS2000's Avatar
needs its own sensor!
Old Jan 31, 2014 | 10:58 AM
cmn's Avatar
cmn
Shouldn't it be possible to hook up the PLX gauge to the OEM sensor as also the sensor that came with the gauge is a 5V sensor? Any reason I can't tap the OEM signal?
Old Feb 1, 2014 | 12:16 PM
99SH's Avatar
The PLX & OEM sensor do not share the same calibration.
UH-60DRIVER
Jul 31, 2016 04:33 AM
erikvanden
May 7, 2011 05:11 PM
DFWs2k
May 13, 2010 04:06 AM
payyourtoll
Jun 20, 2003 04:44 AM
S2K
Sep 13, 2002 12:21 PM
