Wideband install help
Old Jun 9, 2010 | 05:30 PM
erikvanden's Avatar
Default Wideband install help
I am going FI and want to put my wideband gauge in before the SC so I can adjust the air/fuel ratio right away. My question is where do I make the hole for the sensor? In the cat? Before the cat? after? Also is there a test pipe I could buy that would have a bung for the sensor so I wouldn't have to make my own in my current exhaust?
Also I have heard to wire the power to the ignition wire. I am wondering as to where I make this connection.
thanks
Old Jun 9, 2010 | 05:39 PM
AFs2k's Avatar
https://www.s2ki.com/search
There you go buddy.
Old Jun 10, 2010 | 05:24 AM
siadam's Avatar
There you go buddy.
Although I agree with your post, don't be a complete douche.
Your wideband NEEDS to be BEFORE the cat. I usually put mine 18-22" from the turbo.
Usually I find where the stock o2 sensor was, and put it right before/after.
As for power, just find an accessory wire. Meaning one that is energized w/the key is on and stays constant.
Look up under the drivers side dash where the fuse panel is.
Old Jun 10, 2010 | 05:33 AM
TRBOKEV's Avatar
You can ground on the bolt that holds the hood release down there also.
Old Jun 10, 2010 | 09:38 AM
erikvanden's Avatar
Alright. Is there any particular wire I should connect to or should I just start cutting wires until I find one that works?
Old Jun 10, 2010 | 09:40 AM
Little_AP1_S2K's Avatar
NO dont start just cutting wires...... get a diagram all over this forum of what wire does what. and find a power one. :-D
Old Jun 10, 2010 | 12:26 PM
erikvanden's Avatar
Alright. So do I weld the bung at the bottom of the header? The stock O2 sensor is in the cat.
Ill have to look for the diagrams.
Old Jun 10, 2010 | 12:27 PM
SeanSerino's Avatar
I'd weld it into the header. My Berk header comes equipped with an extra bung.
Old Jun 10, 2010 | 12:40 PM
AFs2k's Avatar
I'm tired of seeing the same threads pop up over and over. I mean, it's right there ^. It's easier to do a search than post up a question. Especially one that is simple.
And I'm always down for helping someone out, but this one was just too simple. I searched the same stuff when I installed mine...
Old Jun 10, 2010 | 12:49 PM
g352s2k's Avatar
yeah but what are forums for ya know??? The more they post up the easier it is to find it.
