Wideband install help
I am going FI and want to put my wideband gauge in before the SC so I can adjust the air/fuel ratio right away. My question is where do I make the hole for the sensor? In the cat? Before the cat? after? Also is there a test pipe I could buy that would have a bung for the sensor so I wouldn't have to make my own in my current exhaust?
Also I have heard to wire the power to the ignition wire. I am wondering as to where I make this connection.
thanks
thanks
Originally Posted by AFs2k,Jun 9 2010, 05:39 PM
Your wideband NEEDS to be BEFORE the cat. I usually put mine 18-22" from the turbo.
Usually I find where the stock o2 sensor was, and put it right before/after.
As for power, just find an accessory wire. Meaning one that is energized w/the key is on and stays constant.
Look up under the drivers side dash where the fuse panel is.
You can ground on the bolt that holds the hood release down there also.
Although I agree with your post, don't be a complete douche.
And I'm always down for helping someone out, but this one was just too simple. I searched the same stuff when I installed mine...
Originally Posted by AFs2k,Jun 10 2010, 12:40 PM
I'm tired of seeing the same threads pop up over and over. I mean, it's right there ^. It's easier to do a search than post up a question. Especially one that is simple.
